Re: [Digital BW] Re: Hard drive full
2004-08-25 by knightmaer35@aol.com
I have been looking into purchasing an external harddrive. My question is can
you keep more than one connected and available at a time?
Thanks.
Oops, just found my question regarding connecting multiple external
harddrives had already been answered by Clayton. Thanks!
2004-08-25 by Richard Smallfield
thanks to all of you for your advice. I think your external options are the best ... but due to impecuniosity, I opted for a 160BG internal as I don't have USM2 for firewire. When I upgrade, I'll just transfer the drives into the new box.
You lot make my life a whole lot easier. Thank you all for putting up with my often dumb questions.
Long live the Digital BW list!!!
thanks again,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "I do not consider it an insult, but rather a
   compliment to be called an agnostic. I do not pretend
   to know where many ignorant men are sure - that is
   all that agnosticism means."
   --Clarence Darrow, Scopes trial, 1925.
Re: Hard drive full
2004-08-25 by lenzzman44
We all get there sooner or later. It's sad when you suddenly can't
save a change OR the file!
	As an ongoing solution, routinely transfer new files to a CD-RW.
When the CD-RW gets full, make 2 CD-R copies of it on high quality
media and store one of them somewhere away from the other one (so if
fire or some other failure gets one, the other is apt to be safe).
Clear the CD-RW and your hard drive and start again.
	A CD-RW is not good for long term data archiving, but can be used
multiple times for temporary storage. High quality CD-R (properly
handled and stored) is much more reliable than any of the magnetic
media, including hard drives. Best guesses run around the 75 - 100
year range. Long before that they'll be obsolete, and you'll have to
copy them to the latest best thing.
	Or back up to DVD-R and make a second copy when it gets full. Even
more robust media than CD, but can't be reused.
Good luck!
Jim
Re: Hard drive full
2004-08-25 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lenzzman44"
full. Even
Jim;
Do you have any info supporting the above? I've been doing just
that, but I haven't yet seen any numbers for DVD-R media anywhere,
and I would very much like to.
Steve K.
2004-08-25 by hogarth
NIST Special Publication 500-252 "Care and Handling of CDs and DVDs..."
You can download it off the NIST website:
http://www.itl.nist.gov/div895/carefordisc/
> full. Even
> Jim;
> Steve K.
Re: Hard drive full
2004-08-26 by lenzzman44
Steve -- In a CD, the data dye layer and the reflective layer are on
the top / label side of the disk and more subject to physical and
chemical and light damage. Triple true in "bargain" disks. DVD has
those layers sandwiched is plastic. Hence more robust.
Think floppy disk and you'll see that we mostly have to worry about
the media outlasting their popularity, and not real archival quality
like we're usually talking about here.
A related issue, worthy of its own thread, is my great fear that the
primary legacy of the digital photo revolution will be total disaster.
We've all heard stories of folks running out of their burning house,
leaving jewelry and heirlooms behind, clutching the family photo
album. The thing they can never replace. I see a huge demographic
trusting their priceless family memories to extremely transient media.
I reckon the fraction of folks backing up their digital photo
collection to reliable media is vanishingly small. ALAS!
2004-08-26 by Bob Frost
Joe,
If you use xxcopy and a batch file, you can just click on a desktop icon and
xxcopy will compare your backup and main HD's and just copy the ones that
are not yet backed up. Dead easy. I use it for backing up various folders
and drives on three networked computers. Ordinary xcopy can work, but may
make mistakes in long names apparently. XXcopy prevents this and allows a
multitude of options to put in the batch file.
Bob Frost.
Transferring is a matter of drag an drop.
RE: [Digital BW] Re: Hard drive full
2004-08-26 by Paul D. DeRocco
> From: Bob Frost [mailto:bob@...]
> desktop icon and
XCOPY won't delete backups of files that no longer exist. Will XXCOPY?
Paul,
I think it is one of the hundreds of options, although I haven't used that
one myself yet.
I use a simple set of options that show me on screen what it going on, such
as
xxcopy E:\data\*.* I:\datacopies /BI /E /FF /Po0 /WE
or for copying to a networked computer
xxcopy E:\data\*.* \\home-2\maindata2\datacopies /BI /E /FF /Po0 /WE
I have about a dozen such lines in one batch file, and one of the above
options stops each between each line and gives a breakdown onscreen on what
it copied. Then a touch on the spacebar and it does the next line. You can
run it completely in the background, but I still like to keep an eye on it.
I leave deleted files in the backup at present as a precaution, and just
delete the whole backup if I run out of space, and let it copy the current
files over.
It's free for one computer, but you need a licence for networked computers.
Bob Frost.
2004-08-27 by Peter Marquis-Kyle
This is prompted by the discussion of xxcopy, which I have not used...
I use a program called InSynch -- a Windows program. With this, I duplicate all
my data files onto a backup set on a second computer via Ethernet. I do this as
a protection against hardware failure and (more likely) operator error.
A couple of times each day I click an icon on my desktop, and InSynch
synchronises the two sets of files without any attention from me, copying and
deleting files in the backup set as necessary.
I am a satisfied user, but have no other connection with this program. Read more
here:
http://www.dillobits.com/insync.phtml
Cheers
Peter Marquis-Kyle
2004-08-27 by Bob Frost
Peter,
Not seen it before, but InSync looks quite good for those who do not want to
dabble with batch files and command lines. XXcopy is certainly not for the
faint-hearted!
Bob Frost.
all
as
