Hello
Did you switch the image to RGB mode, then apply the curve, and print the image? The curves can only be applied to the image in RGB mode.
Thanks
Ross
virtuallygrey <stephengledhill@...> wrote:
I've had UT7 inks in my 2100 (2200) for two weeks now and am
delighted with the results that I'm getting using the sliders in the
Epson driver. Clearly there's some trial and error to go through
for each paper to work out personal preferences but I've achieved
superb results. These inks are superb.
But, I first tried the adjustment curves from Paul Roark and found a
real problem. I should say first that I've been through all of the
settings and double-checked everything � but who's to say I've not
overlooked something! They're all as per Paul's directions. For
every one of the curves supplied (for EEM) when applied as directed,
the print tones are heavily skewed. Bear with me as I try to
explain. I've printed several step wedges and smooth wedges using
these curves and all of them print as though they're very low
contrast. The 100% black is full black but it rises very quickly
out of the deep black into dark grey. It then continues at a
flatter rate through to light grey then very quickly rises to paper
base white. The ramp is nowhere near linear. It's similar to (but
not precisely the same as) printing with the contrast slider set to
minus 25, i.e. it's seems to be very low contrast whilst holding on
to the black and white at each end.
If it weren't for the fact that I get brilliant results using the
sliders and UT7 I'd probably have written off UT7 and Paul's
curves. But from what I read in this forum and elsewhere it must be
me and my setup not the inks and curves.
f.y.i. 1 - I use Photoshop CS on an XP Home PC.
f.y.i. 2 - I use a particularly well laid out greyscale available on
John Paul Caponigro's site -
http://johnpaulcaponigro.com/resources/files.html
I must be doing something wrong but I can't for the life of me see
what. Can anyone help please? Thanks in anticipation.
Steve Gledhill
www.virtuallygrey.co.uk
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
