MIS includes small aluminum rivets (1/8 inch dia X about 1/2 inch
long, I think) as plugs for Epson carts with their CFS, you should be
able to buy similar parts in a hardware store. Use them to plug each
cart, seal the reserviors with somthing (there's a clay-like adhesive
called "Tacky-"something that will adhere to the vent hole and help
prevent a spill). Finally, put a set of non-CFS carts in the printer
and you should be all set.
You might want to run the printer with the non-CFS carts until you get
a good nozzle check to make sure the ink supply to the heads is
continuous with the cart volume to keep it from drying out.
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jack McLain -
Contract Research Oversight" <jmclainaz@c...> wrote:
> I own a Epson 2200 which has been retrofitted with a Septone B&W
Continuous
> Ink System. I am moving and need to pack this up.
> Does anyone have any experience with how best to do this. I guess I
am most
> worried about the ink siphoning out once it is disconnected, and any
> residual ink drying and clogging the works during the period (~1
month)
> between disconnect and reconnect.
> thanks much
> regards
> Jack
> Jack McLain
> Tucson, AZ
> http://jackmclain-photography.dotcommunity.net
