Laser printing
Laser printing
2004-09-20 by lou3602002
Hi
Enjoy this list very much.
Very pleased with my 2200 QTR UC EEM B/Ws using XP Home version and
PS 7 on PC. Thanks Roy for making the high quality, low cost RIP
available for the PC.
I also publish a B/W Newsletter with lots of quality B/W photos.
Typically about 20 over 12 pages.
The model boat organization that I publish it for can't afford
Inkjet, so I go the laser route.  Currently using a new Xerox
DocuTech 120 (600 dpi) at a local service bureau and looking at a GCC
Elite 40 (1200 dpi) for in-house use.
My source images are high quality B/W film scans and grayscale in PS
7, and then I use MS Publisher for layout only.  Hope to replace
Publisher with InDesign in the future. I provide the Copy-shop with a
Pack & Go (packaged) CD.
The B/W digital high quality laser printer is all new to me and I
would be interested in any PS Grayscale workflow issues that differ
from the high quality inkjet route.
Want to use a high quality laser paper.  I print 11 x 17 duplex (3
sheets makes 12 pages).  So "show through" may be an issue
with less then 24-pound paper.  Any paper suggestions for the highest
quality laser output?
Also are these lasers "color managed"? What profiles do I use
for proofing in PS 7?   My local Service Bureau is useless since they
use their $100K Xerox 120 as a cheap paper copy-shop machine. So it
is up to me to provide paper and any machine setting unique to the
paper.
Thanks in advance for sharing your laser B/W digital experiences.
Lou      Concord Ma.
RE: [Digital BW] Laser printing
2004-09-21 by ellery
Lou
check with them if their 120 has a rip server ? You may have to run some
experiments with B&W prints to them at different density adjustments on
global via level adjustments and micro via selected area adjustments.
Check with them the settings they send it to printer at - or at least make
sure they sure the same setting each time,
If done right the Xerox's should be able to give a good tonal range but
there is still that subtle line effect due to the printing of the image line
by line. I have seen b& w prints done on the smaller brother of this the
1250 on yupo paper - they are quite lovely,
Paper stock - you might want to go with some thing like mat art paper - wood
free with its inherent texture and lower opacity could dilute the blackness
of the black.
Xerox should have a calibration routine in hardware and software - it
calibrates for tone reproduction - the kodak gray scale target and tone a
kodak color table. But I doubt if they will allow you access to the unit to
run this.
cheers
ellery
  Sent: Tuesday, September 21, 2004 1:40 AM
  Subject: [Digital BW] Laser printing
  Hi
  paper.
  Lou      Concord Ma.
