Re: Lines on Prints
2004-09-20 by Jerry in Houston
I have a 1280 using the MIS UT2 CFS system, mostly using EEM and Pauls curves. I was also getting those pesky lines. Ran lots of nozzle cheaning cycles with no significant improvement. Then, I happened to check my printer settings and saw that I still had "High Speed" checked. When I changed the settings to turn off high speed the lines went away. Go figgur. Try it and see what happens. Slows down the printing process but saves a bunch on paper and angst. Jerry in Houston --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "weareallsosmall" <weareallsosmall@y...> wrote: > hi everybody > > I'm getting lines on most of my prints that extend about a half inch > outside the print area. These lines are all travelling in the > direction of the print head, and are caused by what looks like the > magenta head. In most cases it's just a few lines, somtimes its many > MANY lines, and every so often I get lucky and get a line free print. > Any ideas as to what's causing this and how I can fix it?
> > Thanks > john
