Do they change the tone of the inks?
2004-09-23 by igorw2001
Hi everyone!
3 weeks ago I encountered an annoying thing: I noticed that my fresh
B&W quadtone prints were different when I compared them with older
prints of the same file. As if the tones had shifted, with loss of
detail. And the step wedge I printed looked bad: some of the steps in
the middle area almost blended into each other. Something was not
right, and it had to be the I N K, because when I printed pure
swatches of black, Y, M and C (to be able to view, on the print, the
pure, unmixed B&W inks) I could see and measure that it had changed
compared to how it used to be (I compared it with a print of the same
swatches I luckily made about a month ago).
I applied an extra Photoshop curve to "repair" this, and it
worked quite well.
But now, 3 weeks later, it happens again! Again the prints and step
wedge have changed! I don't want to go one and one adjusting each
time, because it is a lot of work. And it is very frustating to know
that your results are not consistent.
Now, how can it be that inks change tone? I could think of some
reasons:
-they changed the receipe, down in the factory. By mistake or on
purpose. Can that be?
-the inks have got too old. They are about a year old, I guess.
Possible?
Is anyone familiar with this problem? And what should I do about it,
because it drives me nuts?
All the time I've been using an Epson 1160 with B&W Sundance
Neutral Warm Inks (formerly PiezographyBW), and use the Photoshop
curve that Paul Roark kindly provided for this inkset.
Thanks in advance.
Igor Wesdorp
Amsterdam
Re: [Digital BW] Do they change the tone of the inks?
2004-09-23 by Hogarth Hughes
The old Sundance WN inks are well know for the fading and warm shifting
you are seeing. I suggest trying either the Piezotones or the current
range of MIS inks. Current generation inks have pretty much solved this
problem.
Hogarth Hughes
igorw2001 wrote:
>Hi everyone!
>worked quite well.
>reasons:
>Possible?
>Thanks in advance.
>Igor Wesdorp
>Amsterdam
>Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
>- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>Yahoo! Groups Links
I mean the NEW prints looked bad. The "old" (couple of days or
weeks) were fine. That can not have anything to do with fading.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Hogarth Hughes
shifting
current
this
> problem.
> Hogarth Hughes
> igorw2001 wrote:
> >Hi everyone!
fresh
in
changed
same
> >worked quite well.
step
know
> >reasons:
> >Possible?
it,
> >Thanks in advance.
> >Igor Wesdorp
> >Amsterdam
to keep them short.
group Owner and Moderators. See "Group Topic, Rules and
Guidelines"
THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
YAHOO GROUP
INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> >Yahoo! Groups Links
The pigments can settle, if you haven't been printing regularly. The
symptom of this is that the prints look lighter and fuzzier. It usually
takes weeks of inactivity for this to be a problem though. The cure is
to shake the carts and make a few prints, then things should be working
again.
Other than that, I'd call your supplier and ask.
Hogarth Hughes
2004-09-24 by igorw2001
Hogarth, I followed your advice and shook the carts. After that and
after making a few "flush" prints, the prints had regained their
former quality.
So that is it: the pigments drop to the bottom or start to float and
are not evenly distributed through the fluid anymore. Why haven't I
read about this before? Is it not a common problem? Or does it happen
to Sundance inks only?
Thanks for the tip!
Igor
The
usually
is
working
> again.
> Hogarth Hughes
2004-09-24 by Hogarth Hughes
Settling seems to be common to all pigment inks. As manufacturers
continue to make the pigment particles smaller and smaller, they stay in
suspension longer and longer. But eventually they settle. This is
particularly aggravating in the big machines which have long ink lines
running from the carts to the heads. It's really hard to shake up ink in
a 2mm tube. You have to flush the lines either by actual flushing or by
printing. Either way is a PITA.
Glad you are happily printing again.
Hogarth Hughes
>former quality.
>Thanks for the tip!
>Igor
>The
>usually
>is
>working
>>again.
>>Hogarth Hughes
>Yahoo! Groups Links
