re: Switching off 2100 with CFS every day
2004-10-03 by Owen P. Evans
Hello Bernhard,
In response to your question about the 2100's electronics being robust
enough for 24 hour usage; I presume that Epson uses the same electronics in
the 2200 as they do in the 2100 ( except for maybe the 50 Hz vs the 60 Hz
capability ) If so then, I say the electronics are robust enough as I have
had my 2200 on 24/7 for over 20 months and not had any problems at all. Not
one plug up; bad print nor banding etc. I have printed approximately 300
8x10's and 150 11x14's or larger in this  time frame. (both colour & B&W )
Hope that's useful.
Owen Evans
J.33.3
" Many men stumble across the truth, but most
manage to pick themselves up and continue
as if nothing had happened."
--Winston Churchill--
Re: Switching off 2100 with CFS every day
2004-10-04 by Jerry Hadam
I would second what Owen said.
> Subject: re: Switching off 2100 with CFS every day
> Hello Bernhard,
> electronics in
> Hz
> have
> all. Not
> 300
> B&W )
> Hope that's useful.
And what Paul said, I live in a very dry climate (Idaho) and never shut
mine off.
> I suspect this only happens in very dry climates,
> because it's never taken more than one or two cleaning cycles to get
> the
> Owen Evans
> J.33.3
