To Koloshor: about your densitometer
2004-10-05 by igorw2001
Koloshor,
About your 414 densitometer again, if I may. You wrote: "my
particular X-rite (414) cannot combine its cyan, magenta, and yellow
readings to give you a black and white reading, so I usually just
read the magenta channel and call that "density".
However, when I read the PDF manual of your 414, it says that,
besides C, M and Y, it also can show the "V" or "Visual" value which,
I guess, is for measuring density (I asked X-rite about this "V"  and
they replied: Visual is the neutral reporting of Status T,E,G
densitometry it is not a pure average of the 3 colors but a weighting
of the results based on ANSI/ISO specifications).
So why not use this V instead of M as you do?
 I ask you all this because I'm really having a hard time deciding
which densitometer I should buy.
Thanks in advance,
I g o r
