QTR & Qimage
2004-10-17 by sinwen
This question is probably better addressed to Roy, is it possible to use both together QTR and Qimage ? Thanks Michel [Non-text portions of this message have been removed]
2004-10-18 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinwen" <sinwen@f...> wrote: > This question is probably better addressed to Roy, is it possible to use both together QTR and Qimage ? > > Thanks > Michel > I don't think there's any issue. You write out a TIFF file from Qimage or Photoshop or any other similar program and QTR should be able to deal with it. Roy
2004-10-18 by Stephen Billard
The answer is that it is not only possible, it is a good combination. Print the images using Qimage. Print to file into a folder that you have set-up QTRgui to monitor. The image will print as soon as Qimage has finished creating it. -Stephen www.sbillard.org/Stephen
> -----Original Message----- > From: sinwen [mailto:sinwen@...] > Sent: Sunday, October 17, 2004 2:16 PM > To: DIGITAL Black White Print > Subject: [Digital BW] QTR & Qimage > > > > This question is probably better addressed to Roy, is it > possible to use both together QTR and Qimage ? > > Thanks > Michel > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> > Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar. > Now with Pop-Up Blocker. Get it for free! > http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/ucIolB/TM > -------------------------------------------------------------- > ------~-> > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or > you wish to unsubscribe, please edit your Membership > preferences by visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier > messages to keep them short. > - Good manners are required at all time. No personal attacks > or flames. Hostile, aggressive or argumentative users may be > removed from the membership without notice. > - Keep your posts and threads related to the group topic of > digital B&W printing. Users who persistently make off-topic > posts may be removed from the membership. > - By posting on this forum you agree to abide by the group > rules and guidelines, and to abide by the actions and > decisions of the group Owner and Moderators. See "Group > Topic, Rules and Guidelines" in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL > BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE > THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT > YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, > INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN > IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT > YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED > ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, > THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO > THE DIGITAL BW, THE PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > > > >
2004-10-18 by ferdinand_paris
There is one thing here in the Qimage -> QTR workflow that I don't understand - colour or dot gain profiles. I assume if you print PSCS -> QTR a grayscale image which has, for example, a 20% DG profile, then QTR does some sort of conversion. (If this is not right, someone please correct me, as this is not the way that I usually print.) However when Qimage prints to file for input to QTR, it outputs an RGB image, which will generally have some sort of colour profile attached. What does QTR do with this? Perhaps if I was on a Mac, all this would be more obvious. I read that recent thread about the problems with B&W workflow, which I only partly understood. Colour management is well documented (e.g. Blatner & Fraser), but not really B&W tone management, at least not that I have seen. Is there something about this topic somewhere that I can read? F_P --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Billard" <stephen@s...> wrote:
> The answer is that it is not only possible, it is a good > combination. Print the images using Qimage. Print to file into > a folder that you have set-up QTRgui to monitor. The image will > print as soon as Qimage has finished creating it. > > -Stephen > www.sbillard.org/Stephen > > > -----Original Message----- > > From: sinwen [mailto:sinwen@f...] > > Sent: Sunday, October 17, 2004 2:16 PM > > To: DIGITAL Black White Print > > Subject: [Digital BW] QTR & Qimage > > > > This question is probably better addressed to Roy, is it > > possible to use both together QTR and Qimage ? > > > > Thanks > > Michel
2004-10-18 by Hans Van Rafelghem
ferdinand_paris wrote: >There is one thing here in the Qimage -> QTR workflow that I don't >understand - colour or dot gain profiles. > >I assume if you print PSCS -> QTR a grayscale image which has, for >example, a 20% DG profile, then QTR does some sort of conversion. (If >this is not right, someone please correct me, as this is not the way >that I usually print.) > >However when Qimage prints to file for input to QTR, it outputs an RGB >image, which will generally have some sort of colour profile attached. > What does QTR do with this? > > It just prints it fine :-) . As far as I see it there is no color profile embedded in the by Qimage generated TIF file. -- Hans Van Rafelghem http://www.vanrafelghem.com
