Ink not flowing yet after head replacement in 7000
2004-10-28 by john dean
I just replaced the heads on my Epson 7000 today and put in the original set of dye carts
to start with. I did several initial fill procedures and 2 KK2 cleanings. The inks are inching
up the lines now but have still not reached the heads to show a nozzle pattern. The black
channel however is not showing any ink yet in the line.
Is there something else I should do to bring the gravity to the point of filling the heads?
The heads are new and clean as well as all the dampers.
The manual isn't helping me with this.
John
Re: [Digital BW] Ink not flowing yet after head replacement in 7000
2004-10-28 by Mark Savoia
Do a Init Fill.
Mark
>  John
>  If you wish to receive no emails or just a daily digest, or you wish
> this same page.
>  Please follow these basic guidelines:
>  - As threads develop, trim off excess portions of earlier messages to
> keep them short.
>  - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
>  - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
>  - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
>  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Yahoo! Groups Sponsor
> <image.tiff>
> Get unlimited calls to
> U.S./Canada
> <image.tiff>
> <image.tiff>
> 	� 	To visit your group on the web, go to:
> 	� 	 To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> 	� 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Re: Ink not flowing yet after head replacement in 7000
2004-10-29 by richard_h95050
Hi John,
Did you adjust the capping stations after you did the head replacement
and made sure that everything was running free and clear between there
and into the waste tanks?
If you already did an initial fill cycle and you're not seeing full
ink lines, sounds like there is something farther "downstream" -- that
is, assuming you flushed the feed lines and know for sure there isn't
any blockage between the carts and the dampers.
Ernst offered a couple of good "push" or "pull" methods earlier in the
week when we were talking about this. His comments are in this group,
 message #50317 on 10/25, so I'd refer to his suggestions.
Basically, if you know the lines are clear between the cartridge and
the head because you've either pulled liquid through the line with a
syringe or pushed it as Ernst described, then you've got to make sure
that the capping station seal is good. Otherwise, all the inits and
KK2's are "sucking air" instead of ink.
Likewise, the lines from the capping stations down into the pumps and
waste tanks all need to be clear or the pumps can't do their job, and
there are a few ways to skin that cat. I'd start with the capping
stations, though. If the adjustment and seal looks good, Ernst offered
a quick method of priming the system "south of the caps".
Hope this helps...
Richard
> John
2004-10-29 by sdmey4@aol.com
Pull off the dampers, and use a syringe to draw the ink at least to the
dampers, then an INIT fill should get you going. Leave that cover off the dampers
at least untill you get it running and aligned..
Steve M.
2004-10-29 by john dean
Thanks Richard,
Yes, I did clean out the lines from the head to the carts thoroughly with windex and a
syringe and then put distilled water throught them. But I can see air bubbles still in those
lines.
The first thing I plan to do this morning is adjust the capping station. That would make
sense that after replacing the heads they wouldn't be making the same contact. I didn't
realize that was necessary to do an initial fill. Then I will look into Ernst's posts about
bringing the ink into the dampers with the syringe.
If that doesn't work I might have to try other inks. The inkset that I am using is the orignial
dye set that came with the printer. They have been sealed in their original box in room
temperature all this time but the date on them is 2002. But I can't image that being the
problem since all of the lines are doing the same type of slow movement and when I shook
them vigorously in the begining they seemed quite fluid.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "richard_h95050" <richardh@j...>
wrote:
> Hi John,
> Hope this helps...
> Richard
> > John
Re: Ink gradually starting to flow after head replacement in 7000
After the cap adjustment and anothe initial fill things are starting to flow. All my ink lights
are flashing now with the Epson dye carts. Can I put the Piezzo inks back in now on top of
the dye inks in the line? I have heard that this ok. I'm trying to keep this from stretching
out another week with reordering another set of cleaning carts.
John
Re: [Digital BW] Re: Ink gradually starting to flow after head replacement in 7000
2004-10-29 by Mark Savoia
I would DEFIANTLY use cleaning carts first!
Mark
>  John
> this same page.
> keep them short.
> Files section:
> <logo_25x25.gif>
> U.S./Canada
> <image.tiff>
> <l.gif>
> Service.
2004-10-29 by John Vitollo
Congrats! How are the nozzle checks? If ok switch to Piezo inks. If not stay with Epson inks
or are you saying the Epson carts are empty?
lights
of
> John
inks
It is hard to say, if not very very close. All the ink lights are flashing but I imagine that is
because of the number of initial fills  that I have done. These ink computers are crude in
this machine.
The hoses are beginning to fill but not completely there yet. I am about to take off the
head cover and use the syringe to bring ink into the dampers, or at least look at them. I
have some cleaning carts but they are getting very low in a couple of channels too.
But, I'm still not sure about putting piezzo inks on top of the dye inks in the lines.
john
2004-10-29 by Steven Karafyllakis
of channels too.
> john
DO NOT mix pigments with the dyes in the lines! If you are taking
the dampers off anyway, put the remains of your cleaning carts in,
pull cleaning fluid into the dampers with a syringe, then switch to
the pigs, and pull some of that ink into the lines to where the
pigment is JUST getting to the damper. You can do both in one step,
and you can empty out and refill your cleaning cart with windex if
you're running low. And there's no reason with you can't do this one
ink at a time using only one cleaning cart- you could transfer the
contents of all of them into one if you're running low and don't
trust Windex. After you have the pigments just getting to the
dampers, put it all back together and do 4-5 cleaning cycles to
flush the cleaner through the heads, then do a test print. You
should be up and running in under an hour if you don't stop for
lunch or a beer!
Steve Karafyllakis
No ink for nozzle checks after installing heads on 7000
I've installed the heads and brought the Epson dye  ink into the new dampers. There is
plenty of ink in the carts and lines and dampers.
Then did the initializing of the head numbers. Then did initial fill. Then cleaned etc.
There is plenty of ink in the lines and dampers but I can get NO nozzle check at all. Not
even the hint of a nozzle line. This has gone on all day.
I sincerely don't think the pump would choose this particular time to go out. When I do a
head cleaning the pump sounds like it is working fine. Something in the head is not right I
guess. Checked it three times.
Any suggestions?
John
Re: [Digital BW] Re: No ink for nozzle checks after installing heads on 7000
2004-10-29 by Mark MacKenzie
Hi John.  I hate to ask or even suggest this but is it possible that you
didn't unplug the machine when removing the print heads?
I made this mistake when reheading a 9000 printer and had to replace the
mainboard, and CR assembly.  I had the same situation as you describe.
However, that doesn't mean we share the same problems.  I do hope that
your main board, etc. are must fine.
Mark
john dean wrote:
> -Yes, I also did the cap adjustment through maintenance menu.
Mark MacKenzie, M.A.C.
Conservator
1628 Sommerfeld Ave.
Saskatoon, Sask.
S7H 2S6
email: mmackenzie@...
         mmackenzie@...
Check the ribbon cable to the head. It could also be the head board or
the heads themselves. It is never easy or inexpensive to find out.
Mark
On Oct 29, 2004, at 6:21 PM, john dean wrote:
>  ---Yes the printer was unplugged.
> this same page.
> keep them short.
> Files section:
> ADVERTISEMENT
> <image.tiff>
> <image.tiff>
> Service.
2004-10-30 by john dean
If one head is bad, ( such as the new one I just bought, the other one was fine before
)would that prevent the other head from loading ink and from being able to do a nozzle
check also? If so how do you know which head is bad? You would think if a boad or head
was bad I would get a error message of some kind. The manual is not clear on this.
john
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@c...> wrote:
> Mark
> > this same page.
> > keep them short.
> > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> > Files section:
> > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> > AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> > LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> > ADVERTISEMENT
> > <image.tiff>
> > <image.tiff>
> > Yahoo! Groups Links
> > 	• 	To visit your group on the web, go to:
> > 	• 	 To unsubscribe from this group, send an email to:
> > 	• 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service.
2004-10-30 by richard_h95050
Hi John,
I think by the time you're through with this head maintenance, you're
definitely going to be one of our resident experts on the 7000 ;>)
Sorry to hear it's being so uncooperative and giving you such grief,
though. The "school of hard knocks" is definitely a rough course, but
in the end, it's a good one.
Couple of things:
1. I wouldn't spend any more money on inks or cleaning fluids until
you've gone through a couple of more steps and you see something
happening on paper that tells you the heads are firing. You've had
some good advice on this already from others -- what you can use for
substitute cleaning fluids, not putting your Piezo inks into the
breech yet, etc.
2. Glad the capping station alignment seemed to solve part of the
problem for you. However, I wondered if you followed that process
through to completion -- have you actually observed the system pulling
ink from the capping stations and dumping it into the waste pads
during your init and KK2 cycles?
It's not that I think a problem there would prevent your heads from
firing even a dot of ink onto the paper during your nozzle checks if
your feedlines are actually clear, your dampers filled, screens clear,
etc. Rather, it's more in the spirit of knowing that fluid is freely
flowing "end to end" through your system and under its own steam.
You can test this by wetting the capping station and seeing if that
fluid is being pulled down through the pump and dumped onto the pads.
Initially, you don't necessarily have to pull ink through the heads,
and you can even actuate the pump manually -- then, if that looks good
I'd park the heads and make sure you're seeing the same free flow.
Given how stubborn this system is acting, I'm just suggesting it's
prudent to make sure that the entire path from "cart to waste pad" is
clear, unobstructed, pumps working properly, etc. This shouldn't take
too much time.
3. If that all looks good -- and you can definitely ascertain that the
fluid in your carts (whatever that may be) is being pulled through the
system and dumping onto your waste pads, then you're back to the
question of the heads themselves -- but not until then.
4. All this may seem like overkill -- but you're not reporting any
error messages on your control panel, so electronic failure isn't at
the top of the list. Not that the self-diagnostics rule out every
possiblity there, but you just want to be sure that less complex
mechanical systems are doing their part first.
5. Last question here -- and my apologies if I missed this info from
an earlier part in your posting, but it's very important:
Exactly what was the printer doing -- or not doing -- before you
embarked on the head replacement process? Was it printing at all?
Please describe a bit about it's "pre-maintenance state".
Hang in there, John! You'll get this puppy printing beautiful Piezo
prints before long...
Richard
dampers. There is
> Any suggestions?
> John
Hi Richard,
I really appreciate your expertise and help. You, Ernst, and John
Vitillo have been invaluable to my understanding of all this
mechanical stuff.
What you are saying makes a lot of sense to me in reagard to the
suction of the lines and subsequent ink flow into the heads. If I
hadn't manually brought the ink up into the dampers with a syringe,
the hoses might still be empty and full of air.
I am positive that the lines are clear from the carts, which are
epson dye and good, to the new dampers. What I do not understand is
how the overflow ink dump lines work that take the excess head
cleaning ink into the pads below. I want to now go into them and see
if they are clogged. I suspect they might be because eventhough I've
done numerous initial fills and KK2 procedures there is still plenty
of ink in the carts!  It would make sense to me that those overflow
need to be flushed out also but I don't have a clue as to how to do
that. Is that info described in the manual? If the white lines on the
righ end of the printer by the head station ARE clogged,whould that
stop the heads from filling up too?
Before I decided to install the Piezzo inkset I had used the Lyson
Quad and Small Gamut inksets in this printer only. I never had a
problem with them for 3.5 years. They are the only inksets I used in
this printer. I had no real cloggs before, but as Jon Cone has
pointed out, when Lyson inks hit Carbon pigments a stubborn jelly is
created that mucks up everything. My Generations carts did't get rid
of it all obviously.
I haven't given up on this machine because generally it is like new
and hasn't been used all that much yet. The wast pads down under are
very clean and solid. If I can solve this printer I will have learned
a lot and then might consider setting up a used 9500 with the Piezzo
inks also.I hope to be the most enthuastic advocate of this process
in the state of Georgia. But I've got to get some large prints done
first before I rave about them on my website. The results on my two
small printers sure have been outstanding to say the least.
Still at it to the bitter end,
John
> Hi John,
you're
but
> Couple of things:
> breech yet, etc.
pulling
clear,
pads.
good
is
take
> too much time.
> Regards,
> Richard
new
> dampers. There is
in
> > Any suggestions?
> > John
Hi John,
There are three great resources to learn about how these wonderful
machines work. The first is experience. The second is experience. The
third is the good people like Ernst and John V and a host of others
who have been down this road before.
Please note that I do not include Epson in that group of resources
becauser although their manuals are helpful, they entrust all their
support to their authorized service people. The authorized service
people, allowing for some exceptions that I may never have heard
about, know absolutely nothing. Sometimes they get lucky, but
generally they will charge more than the cost of replacing your
printer to go through and rebuild it piece-by-piece and
visit-after-visit just HOPING to get lucky.
At no time to they guarantee what they do will solve your problem
because they don't really know how to solve your problem -- just
replace parts and write VERY big invoices. So you were wise not to
call them because the better choice is always to just buy a new
printer or a Jaguar, either of which you could easily afford by the
time you get through paying for their service calls ;>)
OK, end of rant. I commend your persistence because it's the
pre-requisite to success in this endeavor. Therefore, if you don't
mind let's go back and apply our collective logic to the situation.
However, this is going to take a few minutes of reading so get
comfortable, pick up a "cool one" of your choice and let's chat:
1. If I understand this correctly, there was nothing wrong with the
printer before and you were a happy camper printing with Lyson inks.
Your heads weren't bad, you were having no other symptoms that they
were bad, and life was good. Your prints looked beautiful, but you
were ready to try something else. If we can take that as a starting
point, let's go on -- if not, please fill in the blanks...
2. You wanted to try Piezo inks, so you ran a set of Generations
cleaning carts through the system and loaded your Piezos. Then, before
you could say "KK2 Cleaning Cycle" three times quickly, you were in
"goo land" and had no output from your printheads. Are we still on
track with the experience? If so...
3. We can safely assume two things: first, in fairness to Jon, you
would have probably had this experience regardless of what pigment
inkset you dropped into the system after the Lyson inks. That's
because of the difference in the ph and chemistry between Lyson's and
almost anyone else's ink formula. The result is, with rare exception,
"incompatible". That means goo and clogs and utterances like
"oh-my-God-why'd-I-do-this?". Second, the Generations "Jet Jrano" may
or may not have been the best choice for flushing the system
(chemistry wise) but regardless, the steps you follow to flush out
Lyson inks need to be fairly thorough
4. This now is more of a retrospective question/commentary that may
tell us why you ran into the problems even though you did the Jet
Jrano flush and where we need to go from here:
 - When you did this process, exactly what did you do? Mediastreet
recommends that you put in their cleaning carts, print a purge pattern
until the old ink colors start to become very faint and then put in
your new carts. Was this how you flushed?
 - If so, there are some assumptions made here that could be where
your problems really started; the above procedure for flushing (as
printed on the Mediastreet Website) is reasonable to ensure that the
previous ink is either "almost" completely eliminated from the lines
or at least sufficiently "chemically neautralized" enough to cause no
harm. If there is enough "Jet Jrano" flowing through the lines that
your "purge printout" with the old inks is becoming faint (you did use
their purge pattern, didn't you?) -- then when you put your new inks
into the system there is still a bunch of "Jet Jrano" in your lines
and that is chemically neutral (in theory) so won't interact with your
new ink and by the time the balance of the "Jet Jrano" flows through
the feed tubes with the new ink behind it, the balance of the old ink
should be gone, your heads should be clear, and everyone lives happily
ever after, yes?  (whew!)
 - So then... what do we do? Well, we go ahead and print our purge
patterns until the new ink is flowing full density through the lines
and heads and do a nozzle check and... this is where it gets
interesting... we give a sigh of relief and since it's probably late
at night, we get ready for a few hours of well earned rest. So we shut
down our system, which in turn -- parks our heads!
 - And where do we park our heads? Well, right squarely on the pads
that were previously filled with Lyson Ink, yes? (Please stop me here
if you did something else like replaced or cleaned your parking pads
and waste system when you made your ink change, but since you didn't
mention doing so I'm assuming you didn't and nobody really tells you
about this "gotcha").
 - Now the old parking pads, along with the wipers, caping station
components, lines, pumps and all that apparatus "south" of the carts
and feedlines and new heads you worked so hard to clean --  are still
soaked with... Lyson Ink, yes? You may have varied from the printed
Mediastreet instructions and done some init or KK2 cleaning cycles
with the "Jet Jrano" still in your system and that may have helped,
but those sponges and all the build-up in the rest of the system
probably didn't get anywhere near the cleaning that your lines and
heads did when you flushed them. (Are we getting close?)
 - So at this point, since it's late at night and time to get a few
hours sleep and we've now parked our nicely flushed, clean heads with
new pigment inks in them onto our.... Right! Lyson Ink soaked capping
station pads! (Again, stop me if I'm wrong but this may help the next
person and we can see what else may have caused your problems)
 - Now sponges being what they are, and Epson ink systems being prone
to some shifts in "pressure" when the systems are turned on or off, we
can assume that everything within that system (from the "carts all the
way to the flush pad" doesn't just stay where you left them. The
fluids move. It would be nice to think that they only move in one
direction; that is, out of the heads and into the parking pads, etc.
However, that's not likely the case...
 - What typically happens is that the heads hit the pads, some of the
new ink does flow onto the pads, things mingle, chemical reactions
occur, and things begin to interact. Your clean Piezo filled heads are
pressed firmly into your Lyson Ink soaked pads and since the system is
shut down there may be a bit of back-force from the wet sponges rather
than a vacuum and and pressure changes in the feedlines and before you
can say whatever expletive you'd like to utter at that moment... well,
it's downhill from there especially because you've probably turned out
the lights for the night and all those ph imbalanced fluids have more
than enough time to demonstrate that they don't like each other by
wicking up into your nice clean print heads and mucking up all your
hard work.
5. OK, so that was kind of a long story and if it's true for you then
we're on to something and if it's not -- well, we may prevent it from
becoming true for someone else who follows in our footsteps. In either
event, here's the upshot:
 - Flushing the lines and heads as Mediastreet suggests is good.
However, it doesn't do the whole job as we've just discussed. Piezo
inks hitting Lyson inks in the areas of the capping station and all
places downstream from that point until the fluids exit the printer
into the waste pads -- WILL react and may congeal. It's just the luck
of the draw (or previous bad experience) whether you happened to push
enough cleaning fluid through the rest of the system to neutralize
this or not
 - Now the question is: did you?
 - If not, then we're back to my comments of last night and the
importance of making sure that a chemically neutral fluid is moving
from cart to waste pad through the entire feed system on it's own
steam (i.e., without syringes or suction or pressurization methods).
If not, then the problem is likely rooted in the windy explaination
above, and we've got to get there first.
6. So that's my suggestion for you today. If the OEM carts and lines
still have ink in them, thats great. But before you try pushing any
more of those fluids through your system, move the heads out of the
capping station, lay down lots of plastic and newspaper, put on the
rubber gloves and eye protection and go to work on everything "south"
of the heads. i.e,...
 - if those sponges still had Lyson ink in them, they're probably
mucked up now so you'll want to take some Windex (or your choice of
cleaner) and get them as clear as possible.
 - you need to be sure that the other lines and pump are all clear of
residual "goo" from the chemically incompatible inks. You can do this
by soaking the parking pads (get them clean as possible first) and
then turning the pump and watching what hits your waste pads. Try to
get to the same point you did with your ink lines and heads -- that
is, a reasonably clear fluid resembling whatever you put onto the
capping stations -- exiting onto the waste pads.
 - if you're seeing a lot of "stuff" in the fluid that is dumping out
the waste tubes, then keep flushing. You may want to follow Ernst's
suggestions here and set this up so the fluids are dropping into a
waste collection system. That way, you're not saturating your waste
pads unnecessarily.
 - be careful what you choose for this flush -- while Windex is OK and
tends to be pretty effective for breaking up all kinds of ink clogs,
remember you've got a pumping system with seals and "O" rings in it so
you don't want to let them sit for too long in Windex (just to be on
the safe side). So when things are looking clear, you could do a very
diluted Windex flush or use some distilled water if it won't sit too
long (we don't want things to rust ;>))
7. What now? Well, since you've got Epson ink in the carts and lines
and dampers, you could just "go for it". However, given all this work
you've put into getting things running free and clear "south" of the
capping station, we should probably be cautious. So let's think about
a couple of things:
 - since you pulled the ink from the carts into the dampers using a
syringe, if the capping station lines and/or pump were mucked up it
may be that the heads haven't filled. That was one of the great
advantages to what Ernst described about using a "push" rather than a
"pull" of fluids into the ink feed lines -- that the fluid would
definitely and visibly be forced through the heads
 - if the previous scenario I described with the Piezo filled heads
and the Lyson soaked pads actually took place, then it's also possible
that your heads have some ink in them but are clogged again. However,
you did say you didn't see even a single drop of ink in your nozzle
checks, so it's not likely that every nozzle is completely plugged.
 - that being the case (that the capping-pumping-waste system is now
clear) I'd be tempted to try another KK2 or init cycle. HOWEVER, I'd
feel a lot more comfortable recommending that if you still had a
cleaning solution in your carts and lines rather than Epson OEM ink.
So, I'd have to leave that call up to you.
 - if your heads did get clogged again badly, you may need to pull
them out and give them a soaking to break up the incompatible inks. Of
course, be sure you do this carefully so as not to flood the heads and
damage their internal circuitry. And before taking that step, you can
try Ernst's "pressure method" to see if the heads are flowing and if
there is any need to pull them again because that's a "worst case"
John, you've basically entered the "world beyond the manual" quite a
while ago, though there is some information toward the end of the 7000
manual that describes "power-off" testing of the pump system.
To answer your question about whether problems in this area we're
discussing could be the cause of your woes, I'd say a qualified "yes"
but that remains to be seen. (I hate to sound like an Epson repair
guy, but I've just not been there to say with more certainty).
In either event, you still need to go through the steps of flushing
the old Lyson Inks and any clogs that may have formed in your pads and
pumps and all that to make sure that system is clear and doesn't get
damaged by trying to constantly pull against plugged-up lines.
Hope I've not offended anyone by giving such a long response, or put
John D to sleep ;>) I usually try to keep replys short on the forum,
but this is a problem that many people go through and I'm hoping
therefore it's forgiven that I've taken the liberty to be a bit (or a
lot) more wordy. Given how frustrating some of these problems can be,
I've also tried to add a bit of levity to the commentary which of
course, just adds more words.
Therefore, flames and reprimands are gracefully accepted -- as are any
additional suggestions, perspectives, corrections or anything else
that may help John D arrive expediently at his goal...
Thanks, and hope this is helpful.
Richard
> Hi Richard,
> mechanical stuff.
see
I've
plenty
in
is
rid
are
learned
Piezzo
> John
> <Previous section of thread snipped but online>
