Duotone Grey printing with 2100
2004-10-29 by Richard Smallfield
I've been tempted by the low prices of the 2100 now that it's being phased out.
1. Does anyone know how OEM ink costs are compared with the HP 95 cart? (It's breaking the bank at present.) I could put Eboni in the black position, which would make it cheaper.
2. Is there any rip that enables you to print only with Black and Light Black? It always seemed curious that Epson didn't offer that option.
Secondly, does the smaller droplet size of the 21/2200 printer's replacement model mean that Black Only printing will now be much better than before?
thanks,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "Ask her to wait a moment - I am almost done. "
   --Carl Friedrich Gauss (1777-1855), while working, when
   informed that his wife is dying.
Re: [Digital BW] Duotone Grey printing with 2100
2004-10-29 by Daniel Staver
Here in Norway OEM inks for the 2100 will break the bank too... And then
some. A new set of Epson cartridges costs me around $150 US dollars.
Fortunately I refill my own cartridges, so I haven't had to buy OEM
carts for well over a year. I use 4oz bottles from MIS and each bottle
is good for 10-12 cartride refills, which means the cost comes down to
almost nothing.
It takes some work preparing the Epson cartridges for refilling, but
once prepared they will last practically forever and the refill itself
takes less than one hour for all seven cartridges. You could use a CFS
and skip the refilling entirely, but I like to have the freedom of
switching between different inksets and testing new inks.
MIS has promised some high quality refill friendly 2100 cartridges for
some time now, but so far thay haven't appeared. I understand they're
having some problems with their chinese supplier, which is why we are
still waiting.
You have two choices regarding inksets from MIS. Either their
Ultrachrome quivalent inkset which matches the colors of the Epson inks
very well and won't require any reprofiling, or the UT7 inkset which is
BW only.
Their Ultrachrome equivalent inkset give you beautiful BW prints either
using BO with the Eboni black, or full grayscales using QTR. In fact I'd
say the quality is almost as good as with the UT7 inks. It's mostly a
matter of whether you want that last 5% increase in quality or not.
There really isn't that big a difference. Highlights are a little
smoother with UT7, and if you look at the prints with a loupe you won't
see colored dots.
Of course, I like that last little bit of quality, so I'm still using
with the UT7's :)
> option.
Yes, QTR will do that, although you'll have to add some cyan and magenta
to the mix to cool down the warm brown tone of the light black. There
are already many good profiles available for the most commonly used papers.
> better than before?
Probably, but I understand some of their newer models don't have a BO
mode in their drivers, which would mean you're actually worse off than
with a 2100. Nobody has confirmed this with their latest model though,
but you better check that carefully before buying.
I'd actually recommend not using the latest model. It will take a while
before third party inksets appears, and meanwhile you'll be forced to
pay outrageous prices for OEM inks. The 2100 already has many
established workflows and inksets available, and a large community of
users ready to help you. With the new printers you're mostly on your own
until everybody catches up.
Daniel Staver
http://daniel.staver.no
2004-10-29 by Bob Frost
Richard,
The R800 (wth the 1.5pl droplets), which is presumably the small version of
the A3 printer that is now out in Japan, doesn't seem to have a Black only
setting any more. It does have Monochrome and Grayscale settings, but they
use colored inks as well as black.
Bob Frost.
2004-10-30 by Steve Kale
Has anyone actually raised this with Epson?  I doubt they are aware of the
popularity of the BO method.  Secondly, if their driver uses the colour inks
it would suggest that QTR could do a decent job with the printer also.
However, I understand from Roy that in order to get to the smaller droplet
size you have to have at least 1440x1440 and Gimp doesn't get there.
> From: Bob Frost <bob@...>
> Date: Fri, 29 Oct 2004 20:31:15 +0100
> Subject: Re: [Digital BW] Duotone Grey printing with 2100
> Richard,
> Bob Frost.
Re: Duotone Grey printing with 2100
2004-10-30 by Tom OConnell
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard
Smallfield <r.smallfield@p...> wrote:
> Hi,
phased out.
Richard-
Where did you learn that the 2100/2200 is being phased out? that is
news to me.
thanks,
Tom O'Connell
Re: [Digital BW] Re: Duotone Grey printing with 2100
2004-10-30 by Hans Van Rafelghem
>>Hi,
>phased out.
>Richard-
>news to me.
>thanks,
>Tom O'Connell
Epson has a new printer :
http://www.i-love-epson.co.jp/products/printer/inkjet/pxg5000/pxg50001.htm
Hans Van Rafelghem
http://www.vanrafelghem.com
2004-10-30 by Altaf Bhimji
> pxg50001.htm
And how does this look for B&W? Any progress?
