Neutral B&W With UT2 Inks
2004-10-31 by bellis33624
I recently (a couple days ago) switched from MIS VM inks to UT2 inks
using a 1280 printer with EEM paper and the Roark neutral UT2 curve
for that paper. Instead of obtaining netural black and white tones
similar to a BO print, I get slightly pinkish or slightly warm tones,
which I assume is because the "netural" curve is really a curve
designed to produce a selenium toned look. However, I don't want an
obvious "this print was selenium toned" look, which I never liked in
a darkroom and which I don't like here. I just want good netural
blacks, whites, and midtones similar to what I can get with BO prints
and similar to what I can get in a darkroom.
FWIW, in addition to using the neutral curve I've played around with
the Epson sliders, generally increasing cyan and reducing magenta,
and while that certainly changed the look of the print it still left
me with slightly pinkish looking tones. I have run cleaning cycles,
which MIS tech support said was all that was needed when switching
from VM to UT2 (and, if it matters, I've properly aligned the heads
and I get good nozzle checks).
Could someone either (a) point me to a dowloadable curve that will
produce neutral black and whites with UT2 inks and this printer and
paper, or (b) provide me with slider settings in the Epson driver
that will produce that result, (c) tell me what changes need to be
made to the Roark neutral EEM UT2 curve to obtain netural blacks and
whites, or (d) provide any other suggestions for accomplishing what
I'm trying to accomplish? Thanks.
Re: Neutral B&W With UT2 Inks
2004-10-31 by Bob Michaels
My experience and desires are the same as yours. Tone is a function of
paper choice as well as ink. Read Clayton Jones paper comparison
tests. http://www.cjcom.net/articles/digiprn5.htm Personally, I really
like the Hawk Mountain Condor BW for the images I shoot. That's
neutral with Eboni to my eye.
Bob Michaels
  --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bellis33624"
2004-11-01 by condor_photo
Hello, I use slider of Epson driver with this setting:
Mode Vivid
L -7
Contrast +4
C +10
M -10
Y -4
Namastè
Stefano
