Re: [Digital BW] Re: Permajet inks
2004-11-13 by sinwen
Thanks for this answer John, no clogging problem with VTBax ? Did you ever met any delivery problem with Permajet ? As for papers and profiles I have everything I need to make my own profiles for any couple paper/inks I want to use. For glossy papers , as I am not looking for archival results, I found a very unknown and cheap dye based ink, with virtually no bronzing nor metamerism with Konica paper, good enough for my needs.
----- Original Message ----- From: johndavidgill2003 To: DigitalBlackandWhiteThePrint@yahoogroups.com Sent: Saturday, November 13, 2004 7:30 PM Subject: [Digital BW] Re: Permajet inks I use a VTBlax in an Epson 1160 and the FSChrome in the 2100 and I'm pleased with both - providing you use the right paper - glossy is a non-starter although the lustre is OK. Best results are with the Fine-Art matt papers. Tech support was excellent (and to be honest I did have a few teething troubles) but it was worth the effort. Permajet supply profiles on their website and they have proved to be surprisingly accurate on the colour set-up. They also provide Photoshop curves for warm to cool B&W prints. You can but test sampler packs of the Permajet papers and I would highly recommend doing so before standardizing on 1 or 2 papers. [Non-text portions of this message have been removed]
