MIS-UTFS in Ep9000-cloging
2004-11-18 by panopticongallery
Thank you all for your advice! In the end it was a small leak in one or two of the
dampers which neather I nor the tech could detect at first. All better, for now.
In general, over the course of the last three years, we have noticed more clogging
problems with our MIS in Epson 9000 during the Fall/Winter transition NE, USA(i.e.
humidity drop), so the humidifier is something I will deffinetly do. As to re-fill carts I
have found that using them more than once is generaly a recipy for disaster (ink spilling
all over the cartredge wells, fome, etc.), I still save 50% off pre-filled using them only
once. I also never, ever leave the printer on when it isn't actualy printing, not even for
a minute. I've been doing this since I switched from the FS to the UTFS inkset, about
four full sets of carts, and didn't have a single clog, untill this last unfortunate and
costly incident. In dealing with my 9000's many problems (cloging, nosel deflection, even
alignment) I have found that Epson techs love to blame the third party inkset, it has a
ring of scape-goating to me.
Thanks agean!
Boris Samarov
Re: [Digital BW] MIS-UTFS in Ep9000-cloging
2004-11-18 by Ernst Dinkla
That doesn't happen often but the connection between damper and
the ink tube can be leaking air in. Changing dampers wears out
the seal in time. Shorten the tube by 4 mm and assemble again is
teh remedy.
> once.
One thing to remember with refill cartridges is that you should
puncture the cart first in the printer itself and after that fill
through the hole that is so created. Then the hole will be at the
right spot and less wear will happen later on. I'm not a
supporter of using refill carts too often as the 9000 cart seals
wear out in time, could start leaking and the debris of the seal
is gathering in the damper or worse in the hole of the cartslot
needle (know about 4 cases of the last).  There are also some
small electronic boards just below the cartslots, with leaking
they get a shortcut and usually an error appears on the display.
Most of the time it can be easily repaired  by cleaning the
boards and drying the connectors but it is a nuisance. Part of
the reasons why I made my CIS systems directly to the internal
inklines.
Ernst
