1D Mark II optics
2004-11-21 by claudej1@aol.com
Thanks, Claude. I take your point. And I don't disagree with it. But now I'm curious to know which lenses you'd recommend for getting the highest performance possible from the 1D Mark II instead. Perhaps the zooms are competitive for it, at least in the normal and higher range? Thanks again. -- Sam >For those who would demand the highest performance possible from a beast >such as a 1Ds mark II (I have a 1D mark II and a 20d), I would recomment the >50mm f/1.4, the 85mm f/1.2 L, and the 135mm f2.0, and the 200 mm >f/1.8 L lenses >as the finest glass possible with that very demanding camera. Everything else >is an optical compromise for the sake of convenience or dollar savings. > >Claude Jodoin >working photographer >Tech. Editor of Rangefinder Magazine Since the well site pitch for both of the Mark II's is identical (or almost so) with roughly 2x the sensor area for the 1Dsmk2 over the 1Dmk2, the optical demands are identical and the recommendation the same. The 1D's 1.25 factor means the sensor is smaller and avoid the corner aberrations of the lenses, all other things being equal. [Non-text portions of this message have been removed]
