RGB triads from 50 megapixels
2004-11-22 by claudej1@aol.com
In a message dated 11/21/2004 10:14:51 PM Pacific Standard Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
can see  good reasons for more then 16.7MP, at the sensor anyway,
suppose you could  build a 50.1MP sensor, you eliminate the need for
bayer patterns, you  could use a triad (triangle of pixels), as the
sensor resultion expands  beyond this point you can use over-sampling,
where several triads are  combined into a single file resolution  pixel.
W
I agree. Foveon is already doing this, they just need someone to buy a full
frame sensor from them. If you have the cash, they will do it...........I
talked  to them about it. Problem is, no one wants to change horses in the middle
of the  Bayer Array stream.
Claude
