Re: [Digital BW] Digest Number 2621
2004-11-22 by Roger Smith
Don et all, Thanks for the details on this process and the reference to Tim Rudman's book. Keep us posted on you experiments as they develop (pun intended). Roger On Nov 21, 2004, at 4:29 PM, DigitalBlackandWhiteThePrint@yahoogroups.com wrote:
> Message: 18 > Date: Sun, 21 Nov 2004 17:00:38 -0000 > From: "hill14701" <hill14701@...> > Subject: Re: lith redevelopment - Digital Black and White Output > > > Roger, > > I agree that this topic has relevance for the list, as this is a > hybrid process. I expose > with a 10d, and formerly printed to 1160 BO or Quadtone. While I love > the tones > provided and the ability to print on art papers, I wanted a quality > lustre surface that > did not require spray. I don't know about most of you, but I've never > been able to > spray completely even and the print always look "sprayed." > > Lith redevelopment is purely experimental. On page 106 of Tim > Rudman's "The > Photographer's Master Printing Course," he refers to the process as > being successful > when applied to papers that are initially developed in lith chemistry > - but not when > processed by conventional methods. > > Lith development is highly dependant on the paper used. Those that > work best are > papers that are not developer incorporated (which many RC papers are). > I have no > idea if the paper from mpix.com is developer incorporated, so I am not > certain if lith > redevelopment will work correctly. I do know that they use Polymax as > their > developer. > > According to Rudman, the steps involved are quite simple and can be > performed in > daylight. First, bleach the print to completion in any > ferricyanide/bromide bleach > utilized in sepia toner. Wash the print and redevelop in any lith > developer that is > highly dilute. > > Here is where I believe the process will give a "lith look." On page > 107 Rudman gives > a recipe for Non-LIth alternatives by "adding sodium hydroxide (NaOH) > to your > developer. This compound is produced in the infectious development > cycle when > paraformaldehyde reacts wih sulfite. NaOH can cause burns and should > be handled > with gloves. It works best with PQ developers such as Ilford PQ > Universal." His > recommendation is 5g of NaOH to 1 liter of working strength developer > to acheive a > lith type look to the print. Page 107 gives an excellent print > example and this would > be my starting point for lith redevelopment. > > For any bleach and redevelopment process, you need to have the initial > print darker > than that of the final image. Typically, you would print an image 1-2 > stops darker > and process normally. Wash then bleach the print to completion. Wash > the print and > redevelop in working developer+NaOH as described above. > > I am not certain if this will work as I intend, or how pronounced the > lith apparance will > be when completed. Remember this is only one method to achieve a lith > look on a > darkroom print. It would be just as easy to have a print made that > was two stops too > dark and bleach back to proper print density. Bleaching without > redeveloping or > toning gives the print a brown tone as well as giving the print a > grainy appearance. > There are many additional darkroom practices that can be utilized for > post- > processing, but the best is just experimenting. > > Hope this helps, > > Don >
