Question about refilling C86 carts
2004-11-24 by bjornaagedk
I have just ordered a set of EZN C86 carts from MIS and also a set of 4 4oz bottles for
refilling.
BUT... do I need to buy empty carts as well or can I just fill the prefilled carts when they
are empty??
Are the prefilled C86 carts the ones with the poppet valve that can be easily refilled??
And I guess I need to buy the chip resetter as well??
Re: [Digital BW] Question about refilling C86 carts
2004-11-24 by Lee Hiers
> refilling.
> are empty??
I have refilled the factory-filled Eboni cart a couple times with no
problems.
The prefilled C86 carts I have (at least the Eboni) has a rubber
plug.  I used a hypodermic needle to refill, puncturing the rubber
plug.
I've got a high capacity cart from MIS that needs to have a hole
drilled...I got it several weeks ago, and it's definitely not the
easy-refill type.
Yes.
HTH,
Lee
Lee Hiers
Hubcap Guitarist
Cornelia, GA
dobro@...
