On Friday, November 26, 2004, at 07:53 PM,
> I just used Spyder to calibrate my monitor. Now, everything is very
> slightly pinkish (or very pinkish depending on your point of view). I'm
> not talking about images brought up now after the calibration, but the
> whole general look of the monitor, regardless of what is on it.
> Can someone help me, as I'm sure this is not right?
What target settings (white point & gamma) did you choose? I did hear
of someone complaining about this a while back but don't recall what
the solution was (or if there was one!). A few years back I had a
negative experience with the Spyder and went through three of them
before I finally threw in the towel (all three produced wildly
different results). I hear the new instrument is much better in terms
of reliability, but have not had the pleasure of trying one. I'd
suggest you contact their technical support and describe your problem.
> Also, I assume I should now set the RGB working space of any image
> editing programs to this new profile right (bet that last one pegged me
> for the rank newbie I am)?
Please don't! Steve Upton from Chromix has been collecting color
management myths...the monitor RGB as working space is No. 7 in the
series. He has explained it better than I ever could, so I include it
here:
Myth #7: Setup Photoshop with your monitor profile as the working space.
While this seems to be happening less often as in the past, a recent
article in a popular photo magazine article contained this dubious
piece of advice.
If you set Photoshop to use your monitor profile as your working space,
all new RGB documents will be created using your monitor profile as
their gamut definition. This is a bad idea for a handful of reasons:
1. All colors will be limited to the gamut of your monitor. As all
ColorThink users know, the gamut of your monitor (and sRGB for that
matter) tends to be smaller than that of most output systems. Inkjets,
presses and photographic output methods typically contain cyans,
greens, yellows and even some reds and magentas that monitors cannot
display. Photoshop 5 and later versions effectively disconnected your
RGB file from your display, allowing non-displayable colors to pass
through Photoshop and be printed. This is a good thing, don't undo it.
2. Each time your re-profile your display you will have a different
working space. Color management is enough of a moving target without
changing your working space every 2-4 weeks (you are re-profiling every
2-4 weeks right?).
3. Exchanging files with your monitor profile embedded will cause
confusion. The reactions from people who receive files with embedded
profiles range from "wha?" to "amateur!". As mentioned in past
ColorNews newsletters, when you exchange files with other people you
should convert to standard color spaces such as Adobe RGB (1998), sRGB
and so forth.
Steve Upton
Feb, 2004
www.chromix.com/ColorNews
Eric Bullock
PixelPusherz Imaging
www.pixelpusherz.net
