Tonal range recording
2004-11-22 by claudej1@aol.com
In a message dated 11/22/2004 1:52:39 PM Pacific Standard Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
Subject: Re: Digital f-stop  ranges and the print
Claude
In the message below you seem to be  referring to more than simple
resolution.  Do you also mean the  recordable density range?  I would like a
hear a bit more on  this.  I have been spending a lot of time lately
understanding  graduated filters better (just ordered a set - yes I know I
should already  have been using them).  I would now like to understand how
film f-stop  ranges equate to a) the range of f-stops that can be recorded on
digital  sensor such as the 1Ds MK II and b) the density range that we talk
about  for our prints (Dmax less dMin).  As I understand it one of the  big
benefits of B&W film vs converted colour film is the greater tonal  range
that can be recorded by B&W film.  How does this range  compare with the new
digital cameras?  How much of this range is  printable?
Steve
Boy, you have opened a big can of worms here. Most of the color negative
film (normal C-41 development) has a Contrast Index of 0.44-0.52, which means a
1 stop luminance change in the scene records a 0.14 change in density in the
film. Assuming no major color crossovers, from a pure monochomatic conversion
of  the resultant lumped densities, you can get out to about 15 stops of
luminance  before a shoulder apperars from the straight line and short toe of color
neg.  films. This from a Dmin in the shadows of about .25 to a Dmax of r 2.38
in the  highlights.
B&W films, especially Tmax (per my curve tests circa 1990) can vary  from
3-11 stops with D-76 straight (I wild combinaton to tame I might add) and a  5-11
minute development time. So with B&W, the Contrast Index (CI) varies  with
development, as does the effective shadow thresholld speed, although not as
much as you might think.
ISO states that you need a CI of 0.65 to get the box speed rating. Most
Zoners develop their filme to a CI of 0.55 to match to the CI of #2 paper, which
is a CI of 1.8 in an ideal world. So ISO essentially "pushes" the film a
little  to get their rating, but real users have always derated their film at least
2/3  stop with their "normal development."  So, with severe speed derating
and  an extreme development "pull" you can get a lower CI than color neg. film,
which  is fixed. This could also inhibit the Dmax of the film depending on the
 developer and how it is agitated.
I have achieved densities in excess of 4.0 with Tmax developed in Dektol
(not a misprint), but I never tested for linearity.
So, the recordable density range for B&W film varies all over the map  and is
not necessarily superior to the 12 stop linear capability of some  sensors.
Besides, with digital capture, you can easily increase the dynamic  range with
a separate highlight and shadow range exposure to be blended later in  any
ratio you wish.
This makes blanket statements, in either case, untrue without specific
details of each method.
I prefer the speed and efficiency of digital capture with the
creative/corrective post processes afforded by Photoshop, but that's just me.  I'm too
impatient to go back to the darkroom for any reason. I earn my living  with "click
to print" workflows of less than 1 minute for a 4x6 color print from  high
speed dye subs, and I'm starting to do the same with Epsons, so maybe I've  been
pulled too far the other way by digital technology.
I simply love color pigments AND BO/Quad/Hex/Sept/Oct monochrome inkjet
output on various papers. What a great time to be in the "lightroom" with so  many
great choices.
My handcuffs are long gone along with my toxic chemical dependency.
Claude
Re: Tonal range recording
2004-11-23 by Pieris Berreitter
Claude (and others),
You mention you've seen Tmax density from 3 stops to 11 stops. I've
seen this magical 11 stops (and more) elsewhere, and recall a comment
saying something like "this is only useful in scientific
applications".
First, can this kind of range be obtained simply by asking a pro-lab
to do pull-processing or is other trickery involved?
Second, how useable is such a "high-latitude" negative for a hybrid
process? In theory, one could scan this negative with a scanner
capable of reading a Dmax of 3.2 (about max for Tmax according to the
datasheet), apply curves to reduce range to about 5 stops (thereby
boosting contrast), and print. Would I be able to match the results
of this high-latitude negative to a "normal" negative of the same
scene, assuming the scene does not exceed the latitude of the normal
negative?
Or (my suspicion), would the tonal range of the "high latitude"
negative be so long as to make the scan aesthetically ugly (banding
in dark regions)?
This topic has always been interesting to me.
-Pieris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, claudej1@a...
> From:  Steve Kale <stevekale@b...>
> Claude
would like a
know I
understand how
recorded on
we talk
the  big
range
with the new
> Steve
negative
which means a
density in the
conversion
stops of
short toe of color
of r 2.38
> in the  highlights.
vary  from
add) and a  5-11
varies  with
although not as
Most
paper, which
film a
their film at least
derating
color neg. film,
depending on the
Dektol
map  and is
sensors.
range with
in  any
> ratio you wish.
specific
living  with "click
from  high
maybe I've  been
inkjet
> great choices.
> Claude
Re: [Digital BW] Re: Tonal range recording
2004-11-23 by Hogarth Hughes
I've done some work in this area and have come to some unconventional
conclusions. I'm not saying I'm right. What I am saying is that this
works for me. You will all have to decide for yourselves.
I'm a 4x5 shooter. Currently I'm only shooting Tri-X for B&W. It
routinely handles 11 stops of subject brightness range (SBR), for
example, white flower in full sun, according to my Zone VI modified
Pentax digital spotmeter. It may well handle more, but I've never found
more in any of my landscape work.
The Zone System would have you pull that 11 stop range down to about 8
stops (N-3 or even N-4) to better match the dynamic range of silver
gelatin paper. What I have found is that with a hybrid workflow
(film-scan-inkjet), this is unnecessary. The hybrid workflow lets you
really simplify the Zone System.
Basically, you setup your EI and normal development time just like for
printing in the darkroom. Then, you expose for the shadows (set Zone III
for the darkest part you want to carry texture), and let the highlights
fall where they may. Every sheet of film gets "N" development.
You can do this because the scanner will fit whatever the film density
range is, into the scanner's digital range of 0-255 (8 bit), 0-4095 (12
bit), or 0-65535 (16 bit). This in turn, is an *exact* match to the printer.
For example, say your FB+Fog occurs at 0.12, and your normal Zone VIII
occurs at 1.3. You meter that scene with the white flower in full sun
and find you have a range of Zone I-XI. You take the shot, develop it
normally, and end up with a Dmax of 2.1 on the film. This negative is
virtually unprintable in the darkroom. Yet, if you do a good scan and
set your black and white points well, you get a full range scan with
beautiful tonality from darkest shadows to brightest highlights. This
scan prints fairly easily on an inkjet printer, without blown out
highlights (which are virtually undefined in this workflow).
Of course, there's always a catch. As you drive up density, you drive up
graininess. The highlights (that white flower) are going to be a little
more grainy than if you did an N-3 process. But since I'm shooting 4x5,
a little extra grain is pretty meaningless anyway.
Sounds too easy doesn't it? Well, I'm not asking you to believe it. You
can prove it to yourself. Shoot a scene twice, and give one negative N-3
and one negative N development. Scan them both and pull the files up
side-by-side in Photoshop. When I've done this test, I've found the
files to be virtually identical, except for the bit of extra graininess
in the highlights of the N negative. And that's not going to be
noticeable in a print smaller than about 40x50 inches for me (about 10x
enlargement). The real test is in the prints though, and I've never been
able to get anyone to tell me which print is which.
Sacrilege. I know. I've been told before. So... clearly, YMMV.
Hogarth Hughes
> applications".
> negative?
> in dark regions)?
> -Pieris
2004-11-23 by Tom Baker
Hogarth  -
There has to be some suble or not so subtle (depending on subject) differences in the tow and shoulder areas between the N and N-3 development.  Other than that, what you're saying certainly does seem to make sense.
Tom Baker
Re: [Digital BW] Tonal range recording
2004-11-23 by Steve Kale
Ok so I must confess that this and the other responses blew straight over my
head, not being a zone guy and not understanding film shoulders and toes.
Can I ask some basic questions so that I can follow the discussion:
1)  You speak of 15 stops from colour negative film.  I have heard people
saying that Velvia slide film has just +/- 1 2/3 stops, or 3 1/3 stops, of
workable range.  Are these measurements of the same thing?  (What is the
tonal range of Provia?)
2) How does one convert stops to density? Loosely.  For example, if a
scanner has a rated dMax of 4.8 how does that relate to the tonal range in
stops of film that it is going to scan?
3) Where does the "12 stop linear capability of some censors" come from?
What is the figure for the 1Ds MK II or 1Ds?
4) I think I understand the importance of linearity - kind-of-sort-of - from
printing.  Is this a similar concept? Ie evenly distributed tonal range?
5) At the end of the day we are severely constrained by the tonal range
capability of our printing.  Hogarth mentioned 8 stops for silver gelatin
paper.  How do I relate a linearised print of a step wedge on HPR with a
paper white dMin of .04 and a best black dMax of 1.68 to these figures?
(Wouldn't it be nice if they all used the same scale?)
While the boundaries of the digital print are expanding, I guess we still
need to shoot by compressing the tonal range of the scene with ND filters
(or multiple exposures) so that it can be rendered well in the print -
traditional or inkjet.  I am trying to relate the two (and the steps that
may be in between eg scanning) so that when I get out my spot meter I am not
only thinking in terms of stops but also in terms of my printer's tonal
range.  Sorry if these are basic questions but I think it will help a lot of
people tie all the talk of dMax back to the camera itself.
Thanks
Steve
PS:  this was not meant to be a digital capture vs film capture discussion -
I think the topic relates to both. I do believe there are significant
workflow efficiencies with digital cameras and I am about to make the switch
but relating the tonal range of a scene as measured by a spot meter in
f-stops back to the tonal range of the printer, ink and paper combination
applies to both forms of capture.
> From: <claudej1@...>
> a
> color
> in the  highlights.
> 5-11
> which
> least
> film,
> ratio you wish.
> I'm too
> "click
> been
> many
> great choices.
> Claude
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2004-11-23 by B. Campbell
"Yet, if you do a good scan and
highlights (which are virtually undefined in this workflow)."
Everything you say here makes sense. But I have a couple questions. What do
you mean by "set your black and white points well?"   I would have thought
that if the shadows are placed on Zone III in your example so that the
flower falls on Zone XI with normal development, then there wouldn't be much
choice in how you place the black and white points if the goal is to print
with texture/detail in both the shadows and the highlights. Second, what do
you mean when you say the highlights are "virtually undefined in this
workflow"? I thought the whole point of what you're saying here is that the
negative actually contains texture and detail in zones well above Zone VII
(which is correct, you can actually get up into Zones XIII or even XIV and
still see some tonal separation in the negative) and that textire and detail
can be brought out in the print without minus development when you scan and
print digitally. So why are the highlights "virtually undefined" in this
workflow?
Sent: Monday, November 22, 2004 10:17 PM
Subject: Re: [Digital BW] Re: Tonal range recording
Hogarth Hughes
> applications".
> negative?
> in dark regions)?
> -Pieris
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
I can answer some of this. Disclaimer: I'm bad with off-by-one
errors.
Each stop is twice as much light as the previous. So we will be
working with powers of two here. For digital, an N-bit sensor has a
range of 2^N -1 values. Because it's linear in response (no toe or
shoulder in the curve, it's just a straight line), zone 0 falls on
2^0, zone 1 falls on 2^1, etc. So you see where we might get 11 zones
for a 12-bit sensor such as those found on the 1Ds.
But that linearity bites us because the total number of possible
tones in between zone 0 and 1 is 2 (2^1-2^0), while the total number
of possible tones between zone 10 and zone 11 is 1024 (2^11 - 2^10).
In other words, your shadows have no smooth tonality and the
highlights get them all. (hence the rule when shooting digital:
expose such that the histogram is shifted up as far as possible w/o
clipping objects of interest).
Dmax can be seen as the base-10 logarithm of the total number of
stops of light. For our 12-bit camera, Dmax=log(2^12 -1)=3.6.
Scanners pretend to have a Dmax of 4.8 because they have 16-bit
ADC's. In reality the light source is probably not bright enough to
properly read that kind of density. Plus, there is inherent noise in
the ADC's (usu. at least 1 bit).
Some may think otherwise, but I don't think you need to worry about
your printer's Dmax when shooting. Photoshop can adjust your high-
contrast scan/capture into a lower-contrast printable version. Just
remember when you shoot digital or scan, that the bottom end of the
histogram is kind of worthless as far as tonality goes.
-Pieris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
straight over my
toes.
people
stops, of
is the
a
range in
from?
of - from
range?
range
gelatin
with a
figures?
still
filters
print -
steps that
I am not
tonal
a lot of
> Thanks
> Steve
discussion -
significant
the switch
in
combination
> > From: <claudej1@a...>
negative
which means
> > a
density in the
stops of
short toe of
> > color
Dmax of r 2.38
> > in the  highlights.
vary  from
add) and a
> > 5-11
varies  with
although not as
rating. Most
#2 paper,
> > which
film a
their film at
> > least
derating
color neg.
> > film,
depending on the
Dektol
map  and is
some  sensors.
dynamic  range with
later in  any
> > ratio you wish.
specific
that's just me.
> > I'm too
living  with
> > "click
from  high
maybe I've
> > been
inkjet
> > many
> > great choices.
dependency.
> > Claude
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
the membership
> > without notice.
digital B&W
removed from the
> > membership.
and
group Owner and
in the
Files section:
THE PRINT
„OWNER‰ AND
SHALL NOT
BE LIABLE TO YOU
EXEMPLARY
PROFITS, GOODWILL,
„OWNER‰
AND „MODERATORS‰ OF
POSSIBILITY OF SUCH
DIGITAL BW,
OF YOUR
PARTY ON THE
RELATING TO THE
> > Yahoo! Groups Links
2004-11-28 by Hogarth Hughes
> What do
> be much
> print
What I do is to set my black point to "film base + fog" so that I get
every bit if information I can from the film. White point is set just
beyond the Dmax of the image. IOW, I don't clip either end. This usually
means that I have to use the levels control in Photoshop to fine tune
the image because I end up with a few empty levels on either end. These
I just chop off. I do this in Photoshop because it allows finer control
than my scanner software. You might be able to set your white and black
points exactly where they need to be with your scanner software though.
The point is, don't clip the image data in scanning.
> Second, what do
> that the
> VII
> and
> detail
> scan and
> workflow?
Not highlights. *Blown out* highlights. If I didn't make that clear in
my post, I apologize.
Blown out highlights in traditional photo papers are just analog
clipping. If your scan isn't clipped, your print won't be either,
assuming that you didn't cook the film to the point that it can't cope
either (I've done that by mistake, and it's and ugly sight ;-)
2004-11-28 by B. Campbell
Thanks, I get it.
Sent: Sunday, November 28, 2004 2:51 PM
> What do
> be much
> print
> Second, what do
> that the
> VII
> and
> detail
> scan and
> workflow?
page.
them short.
the membership.
Yahoo! Groups Links
