Re: [Digital BW] Everyfink is pink!
2004-11-26 by sinwen
You were used to see your screen more bluish, you will get used to see pinkish. Bluish was white to your eyes and soon pinkish will be white. If you return to previous setting you will find it terribly blue. The problem is not there, now if properly calibrated, give your pictures the colours you want them to be on the screen, and you should have better results on the output. Michel
----- Original Message ----- From: Dean To: DigitalBlackandWhiteThePrint@yahoogroups.com Sent: Friday, November 26, 2004 12:34 PM Subject: [Digital BW] Everyfink is pink! Hey! I know this was asked here recently, but I can't seem to find the answer by searching. I just used Spyder to calibrate my monitor. Now, everything is very slightly pinkish (or very pinkish depending on your point of view). I'm not talking about images brought up now after the calibration, but the whole general look of the monitor, regardless of what is on it. Can someone help me, as I'm sure this is not right? Also, I assume I should now set the RGB working space of any image editing programs to this new profile right (bet that last one pegged me for the rank newbie I am)? Thanks. Sooner, Dean [Non-text portions of this message have been removed]
