Index out of bounds (5) error code
2004-12-01 by spineasy
I installed the 3.44 version of QUI and I am getting "Index out of
bounds (5)" error codes. I'm using Qimage print to file with the QUI
monitoring a folder that I send the qimage file to. #1 QUI doesn't
seem to see what Qimage is sending and I will stop the monitoring in
QUI to manually select the file.#2  When I do I get the above error
message. I tried rebooting QUI 3.44 with no success.
Greg
Wealth is a state of mind.
Money is just a tool.
Happiness is pedaling + 25 mph on a smooth road.
http://pages.prodigy.net/glockrey
RE: [Digital BW] Index out of bounds (5) error code
2004-12-01 by Stephen Billard
Can you send a screen shot of the Index out of bounds error? Also please
describe the steps leading up to the error.
There is an error in version 3.44 folder monitoring. If you start QTRgui
with monitoring enabled, it doesn't fully enable the function. If you stop
and restart monitoring things should work.
Version 2.1.1 is now available. This version is intended to go with Roy's
soon to be released QTR version 2.1; however, it will work with version 2.0.
Note that some features, such as roll feed and some printing resolutions,
are not supported by QTR version 2.0.
-Stephen
 www.sbillard.org/Stephen
> From: spineasy [mailto:spineasy@yahoo.com]
> Sent: Wednesday, December 01, 2004 10:56 AM
> Subject: [Digital BW] Index out of bounds (5) error code
> Greg
> Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
> Now with Pop-Up Blocker. Get it for free!
> http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> THE DIGITAL BW, THE PRINT YAHOO GROUP.
Re: [Digital BW] Index out of bounds (5) error code
2004-12-02 by spineasy
Ok, I removed the old programs and installed the latest versions of
QTR 2.1 for PC and QUI 2.1.1 . When I set things up to print,
everything works fine up and until the actual printing. The printer
for whatever reason it just sits. I'm looking at the printer status
monitor for the 9600 and documents in queue window. I can see
spooling and printing....but it's not printing. I have the loopback
adapter set up as from the previous set up. The printer works fine
when I'm not using QTRqui. The monitor for the 9600 says "ready to
print" and "Printing" but nothing is coming out of the machine. I
tried qimage print to file, drag-drop, and select image. They all do
the same thing. I put the old programs back and they work. Any
thoughts? The Qtrqui window looks like evrything is there that
should be. I tried sheet feed and roll feed auto cut. I even deleted
the old Curves before I loaded the new programs.
Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen
please
QTRgui
you stop
with Roy's
version 2.0.
resolutions,
> -Stephen
> > From: spineasy [mailto:spineasy@y...]
of
QUI
doesn't
monitoring in
error
> > Greg
> > Yahoo! Groups Links
2004-12-02 by Stephen Billard
We will probably need log files from QTR and QTRgui
-Stephen
> From: spineasy [mailto:spineasy@...]
> Sent: Thursday, December 02, 2004 2:16 AM
> Subject: Re: [Digital BW] Index out of bounds (5) error code
> Greg
> please
> QTRgui
> you stop
> with Roy's
> version 2.0.
> resolutions,
> > -Stephen
> of
> QUI
> doesn't
> monitoring in
> error
> > > Greg
> > > Yahoo! Groups Links
2004-12-03 by spineasy
Look for a personal e-mail with the log files.
Greg
> -Stephen
of
printer
status
loopback
fine
to
I
all do
deleted
> > Greg
Also
> > please
start
> > QTRgui
If
> > you stop
> > with Roy's
> > version 2.0.
> > resolutions,
> > > -Stephen
out
> > of
> > QUI
> > doesn't
> > monitoring in
> > error
> > > > Greg
AGREE
(EVEN
USE
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
