"Set Ink Cartrige" panel message on Epson 7600
2004-12-04 by MARK MAIO
If it is the weekend, I must be printing. If I'm printing, I must be having
a problem.
My setup:
Epson 7600
Piezography in the 220 ml cartridges. Warm Neutral and Selenium sharing a
Museum Black through the StudioPrint RIP.
Late last night I went to hit the eject button after a print had been run
through and I think/assume/but not sure, I hit another button because the
print did not drop and there was an error message that read "Set Ink
Cartridge" and the "LM" panel light was on. I turned the printer off,
unlocked the ink lever, pulled that cartridge out and shoved it back in,
locked the lever and turned the printer on. The error message still showed
up and I can't find any documentation to correct it.
The  LM cartridge is about half full from what I remember seeing on the
level indicator on the front panel before this happened. The other strange
thing is that the LM position is one of my selenium cartridges and I had
been running the last five prints through with the warm neutral inks. Now
when I go into the Epson print utilities, it shows me that all of the ink
levels are full. This isn't true since I know I was about to run out of
"Museum Black" and the warm neutrals were at about 1/4. The selenium's were
at 1/2. I replaced the Museum Black with a full cartridge, turned it on
again and I still get the "Set Ink Cartridge" message.
As I am suppose to be finishing the prints for an exhibition that gets
delivered on Friday, any immediate help will be much appreciated. Since I
get this list in digest form, please respond to me offline at:
markmaio@...
Thanks in advance,
Mark
Re: [Digital BW] "Set Ink Cartrige" panel message on Epson 7600
2004-12-07 by James Haney
Mark,
I am only just now reading this, sorry I couldn't have been more timely.
I had the same problem with my 7600 with UT7 carts from MIS.
In the end I had to get a replacement cart from MIS.
Basically, either the cartridge chip:
A) Has dirty contacts - try cleaning the ship off and re-inserting
B) Has become mis-aligned - try shimming the cart on the top and
bottom. keep an eye on the error screen and wiggle the inserted card up
and down to see if you can get it aligned.
C) The chip is bad. - Apparently sometimes this happens. The chip just
loses its mind and must be replaced. Two options. get a new chip,
remove the old one and glue the new one in its place. Or, get a new
cart.
Realize that the aftermarket carts used by any company other than Epson
are reverse engineered and manufactured overseas in varying states of
quality. A huge part of the third party ink sellers task is getting
quality carts to work properly with the printers.
I know that none of this really made me feel better when I was
wrestling with it months ago but I ended up with a set of carts that
worked in the end.
Let me know how things come out.
James Haney
> strange
