Gloss Optimizer as overcoat-report
2004-12-05 by Steven Karafyllakis
Hello All;
I received the bottle of MIS Gloss Optimizer (GLOP) this past
Thursday and have some results to report that anyone using UC inks
on RC papers will find very interesting.
The first tests were done with MIS UC-clones in a 7600, with Eboni
K. First tests indicate that the GLOP is NOT compatible with EBONI-
it not only doesn't help it in any way, but a heavy enough coat
causes the ink to bead and craze and generally look very ugly.  I
then took out the Eboni and replaced it with MIS Universal K, an ink
I was not very pleased with when I first tried it. I will probably
wind up using with MIS PK. As my final solution for RC papers.
The first quick test I did was to put some in a cheap ($20.00)
Badger air brush and spray it on a couple different papers, just to
see if it was worth the effort to proceed.  Results: GLOP does less
than nothing for matte papers-it actually hurts the DmaX a bit. On
semi-matte RC paper, with the eboni ink, any area that was pure
Eboni was basically un-affected with a light coat, but any other
area showed an increase in Dmax, an major improvement in the clarity
and depth of the image tones, and not even a hint of bronzing or
differential glossing of the surface. Definitely worth pursuing
further!
I then pulled out the old 1270, flushed the K head with ammonia
window cleaner (Windex) and put a virgin cart filled with GLOP in it.
It took three cleaning cycles to get the old junker giving a clean
nozzles test (you have to do it on glossy paper so you can see the
change in reflectivity of the GLOP). I then set in on BO did a
print, and discovered that ....the printer was useless. The C and M
nozzles that had been misfiring in color would shut off in BO.
Well, 'in for a penny, in for a pound' I thought, and repeated the
procedure with my 1280, which up until now has had nothing but dyes
in it, and has very little wear. The nozzle check was good the first
time, so I overprinted several pages of test images I had prepared
the night before. The papers I tested were:
Epson Premium Glossy
Ilford Classic Gloss
Epson Premium Semi-matte-250
Proof-line Photo glossy DP
Oriental Graphica Lustre
Proof-line Semi-matte/DP
Proof-line Photo Lustre
The 'image' was a simple 100% black rectangle applied through
the 'color controls' setting with only the black ink, at 1440 dpi
and high speed on.
Results:
Glossy papers: The Epson PGPP and the PL glossy respond essentially
the same way: a single average coat completely eliminated any hint
of bronzing, and kicked up the Dmax and color saturation enough to
make it worth the effort. One coat however did not even out the
gloss, there was still an obvious difference between lightly inked
highlights and heavier areas. It took a second pass through the
printer to achieve even gloss, though I'm hard pressed to see any
real improvement otherwise.
On these two papers and the semi-mattes, the GLOP dried as quickly
as ink would, so running them through a second time was not a
problem. The GLOP also reduced the overall shine of the paper
considerably, to more of a smooth semi-gloss that looks much closer
to air-dried Fiber-Based paper than anything else I've seen so far.
This was especially true of the Epson PGPP
The Ilford Classic Glossy takes a long time (days) to really dry
out, so waiting 12 hrs before coating it may not have been enough
for a fair test. This paper takes UC inks without any bronzing at
all, but the surface remains fragile even after ti has dried. When I
cotaed it, the coating showed un-evenness in the form of lines
parallel to print head travel, even though none of the other papers
had that problem at the same settings. A heavier coating on the
other half of the test sheet did not help much, and the entire sheet
showed roller and pizza-wheel marks. Perhaps this would work in a
wide-format printer where ther are no rollers after the head, but
with the smaller printers I'm not optimistic. Too bad, since this
kind of paper gets the best longevity ratings in the RC category.
The Semi-matte/Lustre papers also responded similarly to each other
as a group: They coated evenly with only one coat, gained in DMAX,
color saturation and depth of tone, no longer showed any hint of
bronzing, the gloss was perfectly even for all of them. In this
case, instead of reducing the shine, the GLOP increased it, to the
point that the only real difference between the semi-mattes and the
glossies was a bit more 'tooth' in the former. And of course the
second coat needed for the glossy paper. Of the four I tested, I
preferred the final look of the Proof-Line and Epson semi-mattes-
Epson has the smoothest texture of the group, but the Proof-Line
appears to give the best dmax, but the difference is subtle on both
counts. As I don't have a densitometer I can't verify subtle Dmax
differences, and I'm not sure I would even bother with the Universal
K ink. With the coating it becomes almost acceptable, but I expect
either Epson or MIS Photo K to be much better.
 The Proof-Line papers are part of some sample-packs from Adventure
Cam Photo that I'm testing. At first blush they seem to be a very
respectable group of papers, though I need to do more comparisons to
really decide if any of them will replace what I'm currently using.
If I can find a way to apply GLOP to a wide-format print with-out
buying a third large printer, the PL semi-matte may become my medium
of choice for the large display prints I need for my clients.
Coated, and properly profiled, the overall look of the paper would
be indistinguishable from the Fuji Lustre RA paper I used until 6
months ago.
So, to summarize: yes, despite speculation to the contrary, it works
as an overcoat for glossy and particularly lustre papers, and it is
well worth doing if you have a way to do it. Even spraying it on was
relatively easy-it doesn't stink (though I would still avoid
breathing it) and it is fairly easy to get a fine, even coat, at
least with the model-maker's airbrush I used.
Now I'm looking for a large format GLOP solution
Steven Karafyllakis
http://www.stevekphoto.com
Re: Gloss Optimizer as overcoat-report
One more note: after posting this, I took the GLOP cart out of the
1280, flushed the head again and replaced the K dye ink I got a good
nozzle check quickly, there don't seem to be any ill effects so far.
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis" <steve@s...> wrote:
> Hello All;
ink
to
less
clarity
> further!
it.
M
dyes
first
> and high speed on.
> Results:
essentially
closer
far.
I
papers
sheet
other
both
Universal
Adventure
to
using.
medium
> months ago.
works
is
was
> Steven Karafyllakis
Re: [Digital BW] Gloss Optimizer as overcoat-report
2004-12-05 by Steve Kale
Steve
Awesome!  I guess it works as promised and can be fired by a non R800
printer albeit with a little refinement.
> From: Steven Karafyllakis <steve@...>
> Hello All;
Not surprising as the issue that it is meant to treat is the lack of
penetration into RC media by the pigment inks.
> and high speed on.
You talk about "as an overcoat" at the end of your post.  So you printed the
image and then ran it through for gloss or did the gloss go on as part of
the weave?
MIS have pulled the gloss off their site.  I look forward to hen the sell
their version 2....
Steve
Steve
printed the
part of
> the weave?
All of this was done as an overcoat: the tests were printed on the
7600, and then glossed on a 1280 as a separate pass with the Black
Only setting in the driver. I think weaving it in to fill the gloss
gaps might not give you the full benefit: if you applied it only to
the highlights were the gaps are, you would'nt get the kick in Dmax,
or the complete elimination of the bronzing. It is well worth the
extra pass for those benefits.
the sell
> their version 2....
Well that figures... we find a use for it and they pull it off the
market. I hope they do make a version 2, there's a lot of potential
here. I'm hoping someone can come up with a curve set for either QTR
or PRW (that's Paul Roark Workflow, add that to your list, I guess)
that accomplishes the printing with only 5 inks, leaving the K free
for a BO gloss coat pass. Anybody need a project?
Steve
2004-12-05 by Carl Schofield
The QTR UT2 profiles for some of the RC papers already do this - the K
slot is not used and free for substitution with GLOP.  The UT2 dark
gray inks are sufficient to generate a good dmax without using a black
ink (should be even better with post GLOP application).  I believe that
Paul's RGB curves do the same.
Carl
On Dec 5, 2004, at 3:31 PM, Steven Karafyllakis wrote:
> Steve
> printed the
> part of
>> the weave?
> the sell
>> their version 2....
> Steve
2004-12-06 by Steven Karafyllakis
Steve;
I just checked the MIS website; the gloss optimizer is still there.
Did you talk to them and were told it was going to be pulled? I hope
not!  My thanks to Roy for the quick fix on the 7600/9600 QTR; not
only is it running, but the 2880 dpi setting is working too! So now
I've tested the GLOP with a UC B&W image also, though I sprayed it
on rather than using the printer. A very light coat did wonders for
both the RC and Glossy papers. I think I'm in love with the glossy
look, it gets rid of that hard plastic shine and looks much more
acceptable as a fine-art gallery print! I hope MIS don't screw it up
by making it super shiny!
Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> Steve
R800
> > From: Steven Karafyllakis <steve@s...>
> > Hello All;
inks
Eboni
EBONI-
ink
probably
to
less
of
dyes
first
prepared
> > and high speed on.
printed the
part of
> the weave?
the sell
> their version 2....
> Steve
2004-12-06 by Steve Kale
Yes they told me that they were pulling it. Any page on their site to do
with the R800 is now "under construction".
> Date: Mon, 06 Dec 2004 04:25:51 -0000
> Subject: Re: [Digital BW] Gloss Optimizer as overcoat-report
> Steve;
> Steven Karafyllakis
And with the UC (colour) inks, neither Cyan or Magenta are used so you have
two free slots there.  So there is room.   We just need version 2 of the
GLOP.
> From: Carl Schofield <scho@...>
> Date: Sun, 5 Dec 2004 15:45:20 -0500
> Carl
2004-12-06 by Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
clarity
> further!
A few questions (for anyone). How does the GLOP compare to sprays
such as Print Shield or Print Guard? Could the Epson GLOP be removed
from a cart and applied as a spray. I ask this because I've
seen "compatible" GLOP carts sold at fairly low prices --
http://www.inkjetcartridge.com/t054020.html
Finally, I recently tried some Krylon Protect It! (gloss), using a
2200 loaded with UC inks, including the matte black and printing on
_matte_ paper. It also has the effect of improving the depth and
clarity of image tones with no bronzing except in those areas of the
paper where the matte black was used. Perhaps with PK a uniform
effect would be obtained. Has anyone else tried this product? How
about on glossy paper?
Chris Hargens
The Krylon Gloss spray I was referring to is called Preserve It!
rather than Protect It! Interestingly, the spray had a different
effect on PR than on the Illuminata Alphasmooth on which I had
originally tried it. Both examples were color prints. On the
Alphasmooth, after three light coatings, the print surface became
somewhat glossy with an increase in richness in the color and light
bronzing (unnoticeable unless you carefully tilt the print to see it)
in the black and dark grey areas of the print; with PR, however, the
print seems to become darker overall but remains matte. After the
third application of spray splatter blotches started to appear.
Chris Hargens
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Hargens"
to
less
On
> clarity
> > further!
removed
> Chris Hargens
