Yes I only do pano's this one is 13x 53.19 and that you for the tip.
I am using photoshop7 with the latest epson driver from thier site,
on XP and that is all. I wanted to try qtr but had to finish some
prints I sold from a recent show. Wanted a clean break before I
worked on trying new software. Since I have recieved this printer I
have gone through 50 feet of paper no problem. Before I used a r800
same set up , no problems. Then the MIS cartridge and then this. It
is like the printer said, wow you got a lot left, forget it..You
watch the print queu you can see it all spool to the printer, then
start printing, then cancel and delete the file from the printer.
joey
I am using --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael Hung"
<mhkhung@y...> wrote:
> What software are you using to print? It's a 53 inch print so I
assume
> it's a really big pano?
> As for the bad MIS carts (I had them too), what you can do is find
a
> old/empty OEM cart (matching position 007/009 of course), use a
> swiss-army-knife/screwdriver to swap the chips. Then use a utility
> called sscserve to reset the ink level to full.
> http://www.ssclg.com/epsone.shtml
> Michael
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "zimmracing"
> <zimmracing@y...> wrote:
> > Can someone help before I run back to the dark room, or at least
to
> > a printer that works all the time. Due to many of you here
weither
> > you know it or not I moved from the r800 to the 1280. I am
running
> > into a major issue today. When trying to run a print for a
customer
> > the printer deletes the job about 3 inches in to the 53 inch
print.
> > If I switch to fast BO printing then it run just fine. I tried
both
> > BO and color in the quality setting. I do not use a continus
feed
> > system as yet just MIS cartridges. The last carbon cartridge
that I
> > recieved from them did not ever register, meaning the ink light
> > stayed on, so I went to factory Epson inks all around to try and
get
> > this print done. Then this started. I have removed and
reinstalled
> > the driver and am about to chuck this anchor out the window.
Please
> > someone help....
