MIS GP INKS: How to do Duotones, Tritones and Quadtones
2004-12-09 by Joe
I have an epson 1280 using MIS GP color and eboni black.  Color
results with downloaded profiles look great.  However if I try to do
a duotone, tritone, or quadtone the results are awful.  Even if I
convert a grayscale to RGB and apply some color to simulate a sepia
tone the results are awful.  Heavily saturated with one color
dominating even if I reduce the saturation to less than 10%.  Anyone
have any suggestions?  Thanks
Joe
Re: MIS GP INKS: How to do Duotones, Tritones and Quadtones
2004-12-09 by Steven Karafyllakis
Hi Joe;
The PS duotone function is meant as a specifier for offset-litho
printing, so it doesn't work very well for inkjet; I've found it
takes so much fiddling and tweaking that IMO much of the time you're
better off just starting with an RGB file and adjusting the
individual curves to get what you want. It helps however to be
certain where any inconsistencies are being introduced, so try
printing a greyscale and B&W test image with color inks and the
profile you're using, to verify that it is capable of getting you  a
neutral image. Chances are good that it is not, even though it
doesn't show on a color print. Make an adjustment curve to
neutralize any color shifts being introduced by the profile-you
should be able to use the curve /profile combo as a starting point
for most images you want to 'duotone'. Turn it off while you're
working out the doutone colors you want, but turn it on again before
you print, or your results will be skewed by the profile
inconsistencies. After that, add a second ajustment curve and use
the individual RGB curves to provide the color shifts you want.
Since you're having saturation problems, start with some very minor
adjustments, and see what that gives you. Using an s-curve
introduces 'crossover' and gives the split-toned effect, and you can
do that to all three curves, and add more adjustment layers if it
gets crowded on the first one. It's best, however, to keep it
simple, and test-print each step as you go until you figure out what
you've got. When you have a look you like, save the adjustment
layer, and try a new one, until you build a libray to cover your
needs. If you need more detail, contact me off-list, as this is a
bit off-topic for this list.
Steve Karafyllakis
http://www.stevekphoto.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Joe"
do
sepia
Anyone
> Joe
