> Hi!
> Errors!
> QTR FRONT END
> Invalid Floating Point Operation (When opening Gui) (I can open Gui in
> Letter mood but as soon as I change to A4 the same error appears)
> QTR Front End
> Unable to open file (Tif-files sometimes is unable to open sometimes
> they can be opened)
> After trying to open an, sometimes, unopenable tif-file Gui craches
> next time I try to open it)
> Then I get en massage in Swedish that says: ProgramWrong QTRGui.exe
> has generated som wrongs an have to be restarted, something.. In the
> same crach i get tis message:
> SOMETING ELSE
> Access violation at adress 0000000 Read of address 00000000
> Regards Ulf
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Billard"
> <stephen@s...> wrote:
> > What error messages are you getting?
> > -Stephen
> > www.sbillard.org/Stephen
> > > -----Original Message-----
> > > From: ulfstr [mailto:ust@h...]
> > > Sent: Sunday, December 12, 2004 12:22 PM
> > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > Subject: [Digital BW] Quad Tone Rip problem
> > > Hi! I can not get the new QTP/Gui in my W2k/Eps2100 machine
> > > to work properly? The inslall.bat file just creates an empty
> > > directory in C:/program/QTR. So I did copy the
> > > bin/ppd/quadtone directories from the install-dir to the
> > > empty C:/program/QTR-dir. Then I installed the QTPGui. Then
> > > QTP/QTPGui worked for some pictures. Then all of a sudden I
> > > get several of error messages.
> > > I have the first QTR without Gui and that works with the
> > > print.bat-files. It is installed manually as I describes
> > > before. Does anyone know how to install the new version
> > > manually and get the QTR/Gui to work? Best regards Ulf
