Lab Step Wedge, grayscale LAB Space & tonal Linearization simplification request
2004-12-14 by Mr_Misty_44
Being a semi computer illiterate photographer who uses QTR I am not
completely at home with the nuts and bolts of  QTR and LAB discussed
in these threads. If someone in the group could take much of this
discussion and the conclusions and work flow adjustments and boil
them down into a bit simpler explanation and practical application
when the dust settles, I'd appreciate it. Sorry to sound so
dense.Perhaps it could be placed in the FILES.
John H
Re: Lab Step Wedge, grayscale LAB Space & tonal Linearization simplification request
2004-12-14 by Chris Hargens
As a starting point, download the LAB profile that Roy posted -- see
message/52160 -- install it with your other ICC profiles, open up in
PS one of the images you've printed in QTR (open it in your default
grayscale, i.e., working gray) then go to
Image, Mode, Assign Profile and assign the Lab Grayscale profile. You
can preview the difference it makes. If the Lab Grayscale profiled
image corresponds more closely to your print, then it makes sense
that the profile would be the better one to work in when editing your
images for QTR. In my case it does seem to come closer to what I'm
getting out of the printer. Hope this helps as a first step.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mr_Misty_44"
discussed
> John H
Re: [Digital BW] Re: Lab Step Wedge, grayscale LAB Space & tonal Linearization simplification request
2004-12-14 by Steve Kale
John
In essence what we have been talking about is to what extent the printer
space (think density output for each possible pixel value, in 8 bit 0-255)
can more closely resemble our workspace.  That together with how QTR is
calibrated.
Think of a step wedge printed with QTR.  QTR is calibrated such that is
produces steps from 0 (pixel value 255 in 8 bit) to 100% (pixel value 0)
with equal changes in Lab's L value from dMin (minimum density or paper
white) to dMax.  If you were to plot each step's L value you would have a
straight line.  As an example, EEM has a dmin of around 0.04 which is Lab
L=96 and a dMax with Eboni ink of around 1.68 which is Lab L=16.  With Lab,
L goes in a straight line from value 100 (perfect white) at pixel value 255
to 0 (perfect black) at pixel value 0.  I think you can see that if one puts
paper white at 255 (L<100) and dMax at 0 (L>0), even if it is a straight
line it is not the same as the Lab line - it has a different slope, it is
flatter.  So even if we were editing in Lab, our editing space is not the
same as the print space (which would vary depending on the different dMax
and dMin of various papers).
We were then also talking about the benefits, if any, of editing in Lab
rather than Gray Gamma 2.2.  One of the problems with Lab for B&W is that it
is 3 channels rather than just one so we would use a lot more disk space
than necessary.  So Roy came up with the single channel greyscale-Lab - LAB
without the a and b.  Exactly the same as Lab but lower file sizes.
If you have an image on screen and want to bring it into greyscale Lab
without changing the way it looks then use Convert to Profile.  You can
then, if you like, continue editing in greyscale Lab.  When it comes to
printing, however, you will still face the same issue I mentioned in the
second paragraph above.
I hope this helps
Steve
> From: Chris Hargens <chargens@...>
> Date: Tue, 14 Dec 2004 20:39:21 -0000
> Subject: [Digital BW] Re: Lab Step Wedge, grayscale LAB Space & tonal
> Chris Hargens
> discussed
>> John H
