QTR - Weird "Banding" Problem
2004-12-19 by ldina
I'm new to QTR and am using v2.1b and the QTRgui interface on a windows XP machine with a 2200. I'm using Epson mk inks for now. I just printed an image on 13 X 19 EpEnhMatte paper using the UC_EEnhMatte-warm tone curve, with ink limit slider set to 20 to deepen the shadows a little bit. I used 1440dpi and "better" settings. In the setup I fed the paper narrow edge first, but told QTR it was landscape so I could print on half a sheet (image size was 8X10). This is a portrait of a small boy with light features against a black background. In PS, the blacks are totally black (100K) and I saved the file as a grayscale TIFF with embedded gamma 2.2 profile and without LZW compression. When it printed, I saw noticeable banding in the solid black area (pure black to perhaps zone 4 or 5). The bands are not totally even in width and are about 1/2" wide, fading in and out, almost like venetian blinds out of focus way in the background. It is not clogged nozzles, and besides, the banding is parallel to the long edge (opposite of the travel of the rails the ink cartridges are mounted to). I checked the image in PS and the info palette shows the entire area measures 100K. As a reality check, I printed the Image using ImagePrint and there was absolutely no banding. I'm a little stumped. I love the quality of the image printed with QTR, with the exception of the banding. The banding only shows up in the solid black areas, not on the child's face, hair or clothing. I printed it a second time and got the exact same pattern in the exact same locations. I even shut of my computer and cold booted it and the printer to be sure something wasn't corrupted. Any thoughts? It wouldn't be 1440 dpi instead of 2880 would it? I really love this product and would like to get it working. Thanks, Lou
