Installing and Using QTR For Windows
2004-12-22 by bullitt46
I downloaded the package and also got the QTR GUI. After I ran the
installation, it took a little while to figure out where it had
installed it, but I finally tracked it down to the Program
Files\QuadToneRIP folder. There was no documentation in that folder,
but I found that running the self-extracting zip had created a
folder in the directory where I had downloaded it and there was an
RTF file in that folder, so I opened it and read it. It referred to
a Print-2200.bat file which doesn't exist, so I tried the GUI
instead.
The GUI looks similar to the Linux version, which I actually had up
and running once, so I felt I was in familiar territory. However,
when I try to print absolutely nothing happens, except for a command
window that pops up and disappears before I can see what's going on.
I am running XPPro and I am on a network. I have a 2200 on USB001
and shared with the share name Quad2200. Looking at the log files, I
once saw an error of an unknown tag in the TIFF file, so I recreated
the file with Photoshop 6 (it originally came from Photoshop CS
which I thought might not be compatible). Still absolutely nothing.
I am a computer professional, I run the Imageprint RIP on my 7600, I
have previously run QTR on my 2200 from Linux, and I am completely
mystified. Maybe I should just go back to the Linux version?
Stan
Photography by Stan McQueen
http://www.smcqueen.com
RE: [Digital BW] Installing and Using QTR For Windows
2004-12-22 by Stephen Billard
If you set the "DEBUG" option in the GUI, the command window will stay open.
Then you may be able to see what is going on.
-Stephen
 www.sbillard.org/Stephen
> From: bullitt46 [mailto:smcqueen@...]
> Sent: Wednesday, December 22, 2004 7:47 AM
> Subject: [Digital BW] Installing and Using QTR For Windows
> instead.
> Thanks,
> Stan
> Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
> Now with Pop-Up Blocker. Get it for free!
> http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> THE DIGITAL BW, THE PRINT YAHOO GROUP.
Re: [Digital BW] Installing and Using QTR For Windows
2004-12-22 by Walt Farrell
> instead.
You should find Print-2200.bat in \Program Files\QuadToneRIP\bin (at
least, I did).
	Walt
2004-12-22 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Walt Farrell <wftemp1@h...>
> > instead.
> least, I did).
> 	Walt
I'd recommend using the QTRgui rather than the .bat files.  The newer
version 2.1b and latest QTRgui are much more convenient.
Roy
2004-12-22 by steveabrink
> > least, I did).
The only batch file in my folder is quatoneprint.bat ...? Reloaded
and got the same thing...
Trying to print w/o the the GUI because can't get to work (W2k) ...
Thanks in advance!
SteveB
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<wftemp1@h...>
> wrote:
folder,
an
referred to
> > > instead.
(at
> > least, I did).
> > 	Walt
newer
> Roy
2004-12-22 by Stan McQueen
Sent: Wednesday, December 22, 2004 11:59 AM
Subject: Re: [Digital BW] Installing and Using QTR For Windows
> instead.
least, I did).
	Walt
----- End of Original Message-----
Here's my directory listing:
 Volume in drive C has no label.
 Volume Serial Number is 188B-62C0
 Directory of c:\Program Files\QuadToneRIP\bin
12/22/2004  01:59 PM    <DIR>          .
12/22/2004  01:59 PM    <DIR>          ..
12/22/2004  01:59 PM                 0 dirlist.txt
11/30/2004  04:45 PM           585,728 imagetoraster.exe
08/12/2004  12:24 PM             1,710 quadtoneprint.bat
12/04/2004  11:36 AM           868,352 quadtoprinter.exe
               4 File(s)      1,455,790 bytes
               2 Dir(s)  31,082,991,616 bytes free
As you can see, no Print-2200.bat.
Stan
Checked by AVG Anti-Virus.
Version: 7.0.290 / Virus Database: 265.6.3 - Release Date: 12/21/2004
Sent: Wednesday, December 22, 2004 12:35 PM
<wftemp1@h...>
> > instead.
> least, I did).
> 	Walt
Roy
-----End of Original Message-----
I did start out using the QTRgui, but as I mentioned, absolutely nothing
happens when I click on the "Print" button except that a command window
opens, scrolls some text, and closes very quickly. So I thought I'd try the
batch file, but it doesn't exist. I'm happy with Imageprint for my 7600, but
I'd really like to be able to print B&W without metamerism on my 2200 also,
so I'd like to use QTR for that printer. If necessary, I can go back to
using my Linux box for it, but I'd really prefer to use my Linux box for
other things than a print server.
Stan
page.
them short.
the membership.
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
