newbie digital darkroom questions...
2004-12-24 by robertpma2002
Hi.
I'm have some new (to me) toys that I am hoping I can use to produce nice quality black
and white prints from my 35mm and 6x7cm negatives.  Any help, hints or url's would be
sooo appreciaed.  I'm kind of lost at the moment....
Here is what I have:
epson 2450 scanner, epson 1280 printer (with MIS ut2 (eboni) pigment cartridges, an
apple running 10.3 and photoshop CS.
Even at the scanning step I could use help.  Should the target size be 'original'? and then
adjust the print size when I print from within photoshop (print with preview)?  I'm scanning
48 bits at 2400dpi and after adjusting levels and cleaning up dust etc, I convert to 16bit
grayscale.
I read somewhere about using the 'sliders' in the epson print utility, but haven't been able
to find them yet...any OS X 10.3 / photoshop CS advice?
The good thing about being so new to this is that ANY advice will be useful, the bad thing
about it is not really knowing what to ask?
Thanks in advance for any help.
Bob
Re: newbie digital darkroom questions...
2004-12-25 by rgb2bw
Bob,
When I look over your hardware and software, the only thing we share
in common is 35 mm film and Photoshop CS.  So I will limit my
discussion to general workflow topics instead of specifics.
The first thing I suggest is to start an electronic document and
start documenting your capture-to-print workflow.  Also, if you work
in color, make sure your capture-to-print color management tools and
settings are in place.  One of the best books on color management for
photographers is Color Confidence by Tim Grey.  When working in
color, I keep the color profile the same throughout the entire
process.  I personally think B&W photographers should calibrate their
workflow because part of calibration is setting the black and white
points.
Make sure your slides or negatives are as clean as they can be when
scanning. I scan actual size to the maximum resolution (ppi) and bit
depth I think appropriate.  If scanning B&W negatives, I would
recommend you scan the image as a RGB image and not a grayscale
image.  Because RGB has three channels of information, it can store
finer gradations of tone than a single channel color model.
I do not do any sharpening while scanning.  I do all sharpening in
Photoshop.  I use a plug-in called PhotoKit Sharpener by
PixelGenius.  This product provides capture, 'creative' and output
sharpening using a non-destructive technique, which is a good thing.
It also does its sharpening on layers which allows me to add a layer
mask to `deselect' any areas, such as the sky, from the sharpening
affects.  However, be aware that the image sharpening technique it
uses adds pixel-containing layers to the image file and will increase
the size of the file.
You already mentioned using Levels to set tonal range and fixing
defects.  Since you are a CS user, have you tried the
Shadow/Highlight feature to bring out detail in the shadow areas of
an image?
When converting to B&W, there are so many ways of doing it that it
boggles the mind.  Most I don't like for a number of reasons so I
devised my own, which you can read about at
zuberphotographics.com/page_TMSIntro.htm if you care to.  The
advantage of this method (if you use color film) is that even after
the conversion to B&W, the photographer still has full control of
tone globally, locally (using selections and/or layer masks), by
color range, by color channel or by targeting tone itself.  Another
color to B&W method that supports the visualization process of
creating images is one by John Paul Caponigro that is in Adobe's tips
and tutorials section.
When I am ready to print is when I resize the image to the desired
dimensions.  I personally also change the resolution to the `native'
resolution of the printer when I resize.  For example, I have an
Epson 2200 and when I resize the image, I change the file resolution
to 360 ppi because the 2200 will resample the file if it gets
something other than 360 ppi.  However, I still print at 1440 dpi.
Keep in mind that the ppi of the file you send to the printer does
not have to match the dpi you are printing at.
Hope some of this helps.
