Re: [Digital BW] Re: Solving QTR problems -- Good News Update
2004-12-31 by Peter Palmieri
Roy--is the "sheet/roll paper feed problem" refer to the problem of manually feeding thick paper from the front of the printer?
I have a big (and expensive) inventory of 17 X 22 Premier Fine Art 325gs/sq.m that I am longing to use and am awaiting for the fix.
By the way, I have done a complete house cleaning twice, but the front-loading problem persists. Printing from the paper tray is OK (except once it stopped printing 1/3d of the way).
Peter
  Sent: Friday, December 31, 2004 4:31 AM
  Subject: [Digital BW] Re: Solving QTR problems -- Good News Update
  Yes, things have been going on while I was out too.
  I've been able to isolate two major problems --
  1) the sheet/roll paper feed problem
  2) people with multiple drives are likely to have difficulty.
  There are still two known issues that are easily worked around.
  1) Only the 1440 resolutions should be used.   2880 and 720 are not
      working and wouldn't be useful with the current profiles anyway.
  2) There are some foreign character restrictions.  Some special characters
       are a problem in either the filename or the folder pathname.
       Limiting yourself to standard ascii characters will work around this.
  I've sent the info to Stephen and as soon as we can get the simple
  fixes in and a new download we should all be a lot happier.
  Thanks for your patience.
  Roy
  --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael Hung"
  <mhkhung@y...> wrote:
  > Wow.. so much stuff happened over a dinner when I wasn't looking at
  > the messages..
  > First, to resolve problems.. we need to divide and conquer...
  > The following problems are known.. You are likely to have QTR and
  > QTRgui installed correctly already..
  > 1, Print at 2880 on certain papers on certain printers... The profiles
  > are done with 1440 anyway, use 1440.. (Even in the Epson driver, you
  > cannot select 2880 in all papers)
  > 2, Sheet feed vs roll vs manual feed.. The QTR program IS PRINTING..
  > just certain setting's wrong and the printer's incorrectly trying to
  > load paper in the wrong slot. Hopefully we will narrow down the
  > settings/problems soon together..
  > If you are not having the above problems.. (For example, complaining
  > about cannot locate file/directory, etc)
  > - Run Steve's cleanup program
  > - Reinstall as told by Steve.. and
  > - Install to C:\Program Files\QuadToneRIP directory. QTR is tiny
  > anyway, and it likes to be in that directory :).
  > - Print from C drive until we can track down why printing doesn't work
  > in other drives for some people. You just need to save a copy of your
  > image to C drive.. Since you are likely making a copy in
  > Photoshop/QImage to 8-bit mode anyway, save it to a temp file in C
  > drive and print that file..
  > If none of these works, please post the log files (Like the one that
  > print when renamed).
  > Michael
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  Yahoo! Groups Links
