IJC/OPM Windows XP release
2005-01-02 by jbowhaus
Happy New Year everyone.
I'd like to announce the long awaited release of IJC/OPM
( InkjetControl OpenPrintMaker) for Windows XP.
This pre-release version 1.0.0 has most all of the Mac OS X features
with a few major improvements. The most notable new feature is profile
blending through an Alphachannel.  This lets you assign a different profile
selectively to an area of an image thru its alpha mask. You simply paint an
Alpha mask onto your image in PhotoShop, then save as a TIFF file with
it'smask.  Once imported into OPM, you can then assign one profile to the
base image and a different profile to the Alpha mask.   So one example would
be to, use this feature to isolate the shadows of an image and produce true
split-toning, another would be to isolate a unique element of a image and
control the tone of that element.
Another new feature is the RGB channel mixer; this feature lets you
control how a RGB (color) image is converted into black and white.  The
channel mixer feature uses sliders for Red Green and Blue; these sliders can
be linked together so during adjustment the luminosity of the image is
maintained.
For a limited time (until Jan 5, 2005) we will be offering this pre-release
version for $179.95, a savings of $70 off the regular price.  This is a special
offer that you won't find advertised on any of the public pages of our website.
In order to purchase the pre-release version please use this
special log-in info:
Password: ijcopmwin
And go to:
http://www.bowhaus.com/SPECIAL/IJCOPMBuyWINspl.htm
Sorry for the shameless plug..
Joe Berndt
BowHaus, Inc.
Re: IJC/OPM Windows XP release
2005-01-02 by Steven Karafyllakis
Joe, Antonis:
First, a Happy New Year to all, may 2005 have as many interesting
and useful developments as 2004.
This all looks very interesting, but I need to have a few questions
answered before making the leap:
Looking around on the Bowhaus web site, I see that the package comes
with a set of 'starter' profiles, but I could not find out which
papers and inks are covered, can you give us some info on that? Will
there be more profiles available over time?
Realistically, does one need to have a densitometer to make new B&W
profiles, or does a scanner actually work well?
I'm still not clear as to what kind of an ink setup this is intended
for: quadtone, hextone, Ultrachromes, what?
and if it works with Ultrachromes is it ICC compliant? IOW can I use
a third party profile made with, say Monaco, or Gretag, etc.,
Are there any compositing abilities? Can I print several different
images/sizes on the same piece of paper?
Thanks looking forward to learning more.
Steve Karafyllakis--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "jbowhaus"
features
profile
different profile
paint an
with
to the
example would
produce true
image and
white.  The
sliders can
image is
> maintained.
pre-release
is a special
our website.
> Password: ijcopmwin
> And go to:
> Joe Berndt
> BowHaus, Inc.
Hello Steven,
Sorry for the lack of profile information on the web site, a complete list will be
posted on our web site very soon.  IJC/OPM ships with starter profiles for most
all of it's supported printers.  Most of the shipping profiles are for the 2200/
2100 with UltraChrome Inks and MIS UT2. These UltraChrome profiles are
easily modified for the 7600, 9600 and the 4000.  IJC/OPM profiles are not
ICC profiles, so a standard ICC profile can't be used.
Since IJC/OPM is built for any ink set,  IJC ( the profile editor) gives the user a
complete visual system for making and modifying profiles.
General IJC/OPM profile information.
Three main parts to a IJC/OPM profile;
1, Ink Curve shapes (ink partitioning)
2, Linearization
3. Toner adjustment.
Ink Shapes-
This is where each ink shape is set,  this controls where each ink starts, where
it stops and it's actual shape.  In IJC/OPM each ink in your printer is controlled
by it's own unique 16bit spline.  These splines are edited in IJC in the Curve
Shape editor.
When editing a Curve Shape you can use any of the built-in predefined curve
shapes, or completely free hand (Free Edit) your own.  The built in shapes are
designed to be a quick way to make quadtone or hextone profiles.  For
example to make a profile for a 4 color printer (like a 1160) with Quadtone
inks, it's as simple as Selecting the "Black ink Shape" for Ink 1,  the "Dark grey
Shape" for ink 2, the "Mid Grey Shape" for ink 3 and the "Light grey ink
shape" for ink 4., Then print out your Linearization Target read it in and your
done. (More on Linearization later )
In Free Edit mode, the spline editor lets you control the ink shapes by letting
you manipulate the curve by clicking and dragging control points.   This is
similar to the "Curves" window of PhotoShop.  Free edit mode also gives you
the ability of  importing and exporting the these curve shape.  IJC/OPM PC
ships with a complete set of Epson UltraChrome Free Edit ink shapes.  These
can be used on any Epson UC printer, 2200, 7600, 9600 and the 4000. To
make new profiles.
Free edit curves and the built-in Quadtone curves can be used within the
same profile. This is really nice when you are working with a Quadtone inkset
with toners.
Linearization-
Once you have your Ink Shapes, ( ink partitioned ) the next step is to
Linearize.  By definition, linearization establishes a standard, this standard  is
the ideal relationship of each step from hilight to shadow.  IJC/OPM generates
internal targets which you use for Linearization.  IJC will take values read from
this Target from a densitometer,  a Spectrophotometer or you can scan this
Target and import the scan directly into IJC.  These readings are analyzed by
IJC and the corresponding linearization is attached to the profile.
One example of  Linearization would be to use a 2200 profile on a 9600.  You
would simply load the 2200 profile in IJC, print a target for linearization to your
9600.  Then input the readings and save the new profile.
Toner Adjustment-
This is a quick and easy method to modify the tone of a profile.  Profiles with
ink toners or color inks, e.g. Epson UltraChrome and MIS UT7.
The toners can be linked to a slider,.  These sliders can be in linked together
or independently adjusted.  This gives the user the ability to modify the tone of
a profile in a quick and easy method..
Joe.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis"
<steve@s...> wrote:
> Joe, Antonis:
2005-01-02 by Peter
Hi Joe,
Congratulations on the release. What are your plans for registered
users of IJC/OPM who want to switch over from the Mac version to the
Windows XP version?
Peter.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jbowhaus"
2005-01-02 by yah_group
Is this exactly the same software that will be part of the Lyson
Daylight Darkroom package ?
David
2005-01-02 by johndavidgill2003
Is there not a demo version available - $179 is quite steep for a
step into the unknown.
Secondly by "pre-release" are we saying that the "release" version
will have extra features or just a higher price?
2005-01-02 by Doug Nielsen
Question for Bowhaus - Will the new features incorporated in the Windows XP version also
be incorporated into the the Mac version (and when)??
Doug Nielsen
Hi Joe, a couple more questions:
gives the user a
In a related post Peter mentioned that OPM is a standalone program;
does that mean that one could work up the profiles in IJC and print
them in any standalone program, like Qimage, for instance? How are
the profiles applied, are they adjustment layers as in Paul's
workflow, are they imbedded, which part of the IJC/OPM duo actually
applies them? I ask because very high on my wish list is the need to
have multiple-print compositng somewhere along the line without
having to make really massive Photoshop documents. If I can print
from Qimage or better still, Quark, it would make a huge difference.
predefined curve
in shapes are
For
Quadtone
1,  the "Dark grey
grey ink
it in and your
How difficult would it be for someone like me, who has a good
flatbed scanner but no densitometer, to re-assign and profile5 ink
channels in a 7500 to print neutral to warm matte inks, and reserve
the K channel for a gloss optimizer for RC prints?
Steve Karafyllakis
Re: [Digital BW] Re: IJC/OPM Windows XP release
2005-01-02 by Joe Berndt
On 1/2/05 7:41 AM, "Steven Karafyllakis" <steve@...> wrote:
Hello Steve,
OPM and IJC are two separate programs, you can run one without the other.
OPM is the printing portion, you use OPM to import a image, position it on
the page, select a profile from a popup menu and print.  IJC is the program
that makes and modifies the profiles used by OPM.
Currently you can only print one image at a time in OPM.
Joe
> gives the user a
> predefined curve
> in shapes are
> For
> Quadtone
> 1,  the "Dark grey
> grey ink
> it in and your
> Steve Karafyllakis
Hello Doug,
The new features in the Windows version came about through the inspiration
of development.  So as both products grow the best of each will remain and
at some point in the future I¹d like to have both the MAC and PC version
identical.
Joe
> version also
> Doug Nielsen
2005-01-03 by bwbonkers
Karafyllakis" <steve@s...> wrote:
Steve wrote...
No. The profiles created in IJC can only be used in OPM. They are not
the same as ICC profiles.
Peter
