New to digital darkroom printing
2004-12-31 by joshscapes
Hello,
I am one of those people who has fought going digital and am now
waving the white floppy disk of defeat.  I would appreciate some
advice as I venture into this new forum.
I photograph black and white with medium format b&w film.  I am
planning on scanning my negatives and printing from those scans.
Can you guys recommend a good scanner for medium format negatives?
Can you recommend a good printer for b&w prints up to 16X20 inches?
Thanks in advance.
Josh
Re: New to digital darkroom printing
2005-01-03 by rgb2bw
Josh,
Try looking at the Nikon 9000ED film scanner.  It is both a 35mm and
medium format film scanner.  Go to the www.nikonusa.com web site and
under photography, click on scanner.  I have the 5000ED and really
like it, but the 5000ED is 35mm only.
For my B&W printing, I have an Epson Photo Stylus 2200 printer and
use ColorBytes ImagePrint RIP.  The 2200 can only go up to 13x19 on
sheet paper and 13x44 on roll paper.  Given your dimensions, you may
want to check out the Epson Photo Stylus 7600.  It can print up to
24" wide.  The Epson site is www.epson.com.
Thomas
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joshscapes"
<joshrandall@j...> wrote:
> Hello,
> Thanks in advance.
> Josh
2005-01-03 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joshscapes" <joshrandall@j...> wrote:
> Hello,
Hi Josh. Welcome to the neighborhood.
Don't wave floppies. The corners are hard enough to poke someone.
Oh, you meand advice about scanning and printing...
I'll have to throw my voice in with Thomas. A Nikon Nikon 9000ED is the way to go. You might consider the older 8000, if you can find one cheap, used, and clean.
Epson 4000. It prints 17 inches wide by just about any length. Smaller, lighter, easier to handle than the 24 inch wide Epson 7600. The dot size is smaller than the 7600, so theoretically you'll get a little more detail and les inkjet dots showing. In practice, you'll be hard pressed to tell the difference between a print from a 4000 and a 7600, even under a loupe.
Are you going to print color occasionally, or purely B&W? The 4000 is a much better machine if you ever need to switch from color to B&W. It has eight ink tanks, which are normally loaded with cyan, magenta, yellow, light cyan, light magenta, photo black (the full strength black that works on glossy papers), matte black (the full strength black that works on matte papers) and light black (a diluted black for light tones). The older 7600 only has 7 tanks, you can't have both matte black and photo black in at the same time. If you want to switch from glossy to matte on a 7600, you have to pull the photo black tank, slide in the matte black tank, and let the printer purge its ink lines. It's the purging process that's the problem, it wastes around $50 worth of ink, every time you switch from glossy to matte or back.
If you're only going to use the printer for black and white, and will never, ever do color, this isn't a problem. You can get a special black and white inkset that uses the 7 tanks of a 7600 very well for both matte and gloss. You set it up with two different 100% blacks (one for matte, one for gloss), three other diluted blacks, a warm tone "tint" ink, and a cool tone "tint", and you're loaded for bear with just 7 tanks.
Whichever printer you go with, 4000 or 7600, stock color inks or special black & white sets, you do want to obtain and learn a RIP (raster image processing) program. Harrington's QuadTone RIP is excellent, and cleap ($50). ImagePrint is more sophisticated, and around $500.
You're going to find this stuff annoyingly complicated at first, but soon it will be second nature to you. It's actualyl simpler than a wet darkroom, it just looks more complicated at first glance, becuase it's so new and different.
RE: [Digital BW] Re: New to digital darkroom printing
2005-01-04 by Josh Randall
Thanks for your great advice.  I have been feverously researching this
"switch" for some time now and this forum is the best source of
information I have found.  This tells me that this truly a new breed of
photography.  Thanks again for the assistance.  I truly appreciate it.
JOsh
Sent: Monday, January 03, 2005 7:01 AM
Subject: [Digital BW] Re: New to digital darkroom printing
> Hello,
used, and clean.
under a loupe.
tanks.
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129ugqe5s/M=298184.5639630.6699735.3001176/
D=groups/S=1705019182:HM/EXP=1104850900/A=2495208/R=0/SIG=11egg01lg/*htt
p:/www.netflix.com/Default?mqso=60188914> click here
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=group
s/S=:HM/A=2495208/rand=226815246>
  _____
Yahoo! Groups Links
*         To visit your group on the web, go to:
*         To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject
=Unsubscribe>
*         Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/>  Service.
