Re: [Digital BW] Toned B&W prints and metamerism
2005-01-05 by BKPhoto@aol.com
Sonia-
Briefly, metamerism happens all the time with both inkjet and wet darkroom
prints. Its most noticeable when printing grayscale because our eyes are much
more sensitive to shifts in hue when seen against a gray field. If you see a
metameric shift in a grayscale print made with a given printer, ink set and paper
combination, it is also occurring to some degree when the same combination is
used to produce a color print. It just isn't as noticeable. Some inkjet
combinations are more prone to metamerism than others.
If you add color to a grayscale image--perhaps by duotoning or converting to
RGB to tone the image--the added color information in the print may help
camouflage metamerism.
This is just one of the reasons why so many photographers tend to view a
"neutral" grayscale print (however that is defined) as a "final frontier" issue.
Bill Kennedy
Associate Professor of Photocommunications
St. Edward's University
512/448-8680
