Sent: Tuesday, January 04, 2005 8:52 PM
Subject: RE: [Digital BW] ANOTHER C86/EZ question, about refilling.
>Could someone please provide me with the link for the MIS easy refill carts
>for the C86? I am dizzy from moving around their site.
Here's a picture of one:
http://www.inksupply.com/index.cfm?source=html/c84refill.html
This is where they list the carts by part #:
http://www.inksupply.com/index.cfm?source=html/epsonempty.html#C84
Of course, there is no way to know for sure if the numbers all relate to the
new carts or some older ones. The fact that the re-fill instructions are
just for the new, good ones might be a clue.
__________________________
Sent: Tuesday, January 04, 2005 9:25 AM
> ... wanted to confirm that the CMY cartridges all do use the
>exact same ink
The EZ gray inks are all the same density. The chips for the carts are
unique to each "color" spot. For example, I have just one pint bottle each
of EZ-Warm and EZ-Neutral. However, I have a couple spare chips for each
spot. Although the re-setter (modified as shown on my web page, accessed
from http://home1.gte.net/res09aij/index.htm ) has worked perfectly on the
C86 chips, on other printers I've found the chips sometimes don't reset
correctly.
> ... could you provide a bit more info on how you "prime" the cartridge ...
I first fill the new, empty cart through the hole at the top of the
reservoir. I wait a while for the sponge to get soaked, and add enough ink
to almost fill the reservoir. After I've "corked" the hole securely (but
without pushing the stopper down so far I can't remove it), I turn the cart
almost completely upside down, so that the outlet (still sealed) is
accessible and pointing up. I tilt the cart just enough so that the ink in
the reservoir is still covering the connecting passage between the reservoir
and sponge-filled section. The connection is very close to the outlet. I
want ink there so that when I pull ink out of the outlet it does not pull
air through that passage.
I then use a syringe with a shortened bottom fill adapter on it, and I
puncture the seal over the cart outlet. I use a regular bottom fill adapter
with the snout shortened to 7 mm. (MIS also sells a modified bottom fill
adapter that it has put a small tube on, supposedly for these poppet carts.
I'm not sure you can puncture the seal with these, however.)
Once the seal is punctured, I push the bottom fill adapter into the outlet,
with the cart in the almost upside-down position, and pull a bit of ink out.
The hope is to pull the air bell out that is usually right at the outlet and
can require a lot of cleaning cycles to remove. So, when I first start to
pull on the syringe, I get air. Once the ink starts, I'm done, and
hopefully the cart will start with a perfect nozzle check right after
loading into the printer.
they are often being updated.
page.
them short.
membership without notice.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
page.
them short.
the membership.
Yahoo! Groups Links
page.
them short.
the membership.
Yahoo! Groups Links
