Re:] Digest Number 2734 3M Positionable mounting adhesive
2005-01-05 by ArleneLoveL@aol.com
I've used it for years for presentations, but not for  archival prints . If
it IS archival - someone -  please let us know, because it's so easy and always
perfect.  No waste, and no machinery or tools needed except the little
plastic squegee included in the box. If it IS archival, it will save a lot of money
& time.
            Arlene
www.arlenelove.com
Re:] 3M Positionable mounting adhesive
2005-01-06 by mark_gatehouse
> prints . If
> easy and always
little
> save a lot of money
> & time.
>             Arlene
> www.arlenelove.com
Wilhelm lists it as the preferred method for permanent cold mounting
polyester based prints (as well as RC based prints) in his standard
text on colour photographic materials (he also recommends against dry
mounting for colour and other materials for museum and archive
collections)
Most Conservators would advise against most forms of dry mounting for
any kind of photogrpahic (or inkjet) prints for the long term. Aside
from the general lack of data about the long term effects of the
adhesives as well as the effectiveness of the adhesives over time,
the differentials of joining the two surfaces is problematic.
I once saw a lovely Ansel Adams print at the National Gallery of
Canada which had been kept in non-archival conditions for the first
part of it's life. Flexing over the years and differential expansion
and contraction between the print base and the backing mount has led
to small ripples in it. Even though it was mounted with "standard"
mounting tissue it proved virtually impossible to repair.
Basically, for long term "archival" storage, just don't dry mount. If
you dry mount then it isn't "archival" (whatever the manufacturers
claims might be). Most texts from conservation institutes will advise
against it. If you are dry mounting for display then it isn't meant
for long term "archival" storage.
2005-01-06 by outlaw07480
Arlene, I have been using 3M Positionable Mounting Adhesive to mount
Ilfochrome CLM.1K (that's the polyester stuff) to non-buffered board
for the past eight years.  I haven't had a failure or suffered any
discoloration yet.  I roll mime on with a Coda roller press.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mark_gatehouse"
> > prints . If
> > easy and always
> little
> > save a lot of money
> > & time.
> >             Arlene
> > www.arlenelove.com
mounting
dry
> collections)
for
Aside
expansion
led
If
advise
2005-01-06 by bwinkjet
Hello,
This is a response from 3M regarding the film.  They now make an
acid free version.
"Thank you for your interest in our Scotch (R) Cat. 568 Positionable
Mounting Adhesive.
This product is available in two formulations; our original formula,
and
the new, acid-free formula.
The original formula has been used extensively by professional
framers for
many years; the acid-free version was developed in response to
customer
requests for an acid-free product.
"Archival" is a claim not used on Scotch(R) brand adhesive products,
since
there isn't an industry-standard definition or test procedure for
verifying
this claim.
That said, both versions of this product will provide a permanent,
professional mounting adhesive, for bonding prints, photos, etc. to
smooth,
high-quality mounting surfaces.
I hope that this answers your question; if you have additional
questions,
don't hesitate to contact us again.
Lucinda
3M Stationery Products Division"
HTH
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "outlaw07480"
mount
board
> --- In
archival
> > > prints . If
so
> > > easy and always
> > little
will
> > > save a lot of money
> > > & time.
> > >             Arlene
> > > www.arlenelove.com
> mounting
standard
against
> dry
> > collections)
mounting
> for
> Aside
time,
first
> expansion
> led
with "standard"
mount.
> If
manufacturers
> advise
meant
