New digital inerneg material
2005-01-06 by Steven Karafyllakis
Anyone out there still working on digital internegatives? A few
weeks back I got a few sheets of a film called Super Clear/IJ from
Michael Pach and Adveturecam Photo. I've tried it a couple times at
this point, and I'm pleased enough with it to ressurect that
particular project. I had been trying Pictorico products, but
remained unsatisfied: I hate printing through the almost opaque
white plastic paper, and the OTC showed printer artifacts: the
printer dots where very clearly delineated, it showed microbanding
when normal paper wouldn't and the film itself was milky, lowering
the effective contrast, and has a lot of microscopic flaws. Also,
and probably most important, the Pictorico won't build much density
or color saturation. It seemed no matter how I went about it, I
could get enough density, spectral or otherwise to get good
contrast. Not a problem if you're using variable contrast paper, but
I need the internegs for printing the hand coated emulsion, which is
a grade two at best.
OTOH the Super Clear is, as its name implies, much more clear, at
least in part because it is thinner, so carefull handling is a must.
On the plus side, it is capable of producing much better color
saturation, especially in the yellow range where the Pictorico was
very weak. That makes it easy to produce an orange negative of
enough spectral density to make a snappy print on VC fiber paper at
a grade 2-2.5
Also, it shows printer dots less, and doesn't seem prone to showing
microbanding either. I think this is becuase there is a bit more dot
gain, which softens the edges of the printer dots a bit. Obviously
this also means slightly lower max sharpness is possible, but the
difference is not visible to the naked eye, and you have to look
carefully even with a lupe to pick it up. The lower grittiness is
definitely visible to the naked eye, and quite pleasing.
There is one catch: the material is available in 100 sheet boxes,
and while the price per sheet is much lower than Pictorico, that's
still a good chunk of change. Michael has agreed to split the
packages into 50s that's a lot easier to handle, and puts the cash
outlay close to what you'spend getting into Pictorico.
Hope this is of some use & interest
Steve Karafyllakis
RE: [Digital BW] New digital inerneg material
2005-01-07 by Ken Carney
Steve, is your hand-coated emulsion platinum or palladium or a combination?
As you know these require a neg with a DR greater than a neg for silver
paper.  If this film will work for pt/pd or Ziatype that is good news
indeed.  Also, are you using dye or pigment inks?
  --Ken Carney
    www.kencarney.com
> From: Steven Karafyllakis [mailto:steve@...]
> Sent: Wednesday, January 05, 2005 7:11 PM
> Subject: [Digital BW] New digital inerneg material
> few weeks back I got a few sheets of a film called Super
> Clear/IJ from Michael Pach and Adveturecam Photo. I've tried
> it a couple times at this point, and I'm pleased enough with
> it to ressurect that particular project. I had been trying
> Pictorico products, but remained unsatisfied: I hate printing
> through the almost opaque white plastic paper, and the OTC
> showed printer artifacts: the printer dots where very clearly
> delineated, it showed microbanding when normal paper wouldn't
> and the film itself was milky, lowering the effective
> contrast, and has a lot of microscopic flaws. Also, and
> density or color saturation. It seemed no matter how I went
> about it, I could get enough density, spectral or otherwise
> to get good contrast. Not a problem if you're using variable
> contrast paper, but I need the internegs for printing the
> hand coated emulsion, which is a grade two at best.
> clear, at least in part because it is thinner, so carefull
> handling is a must.
> color saturation, especially in the yellow range where the
> Pictorico was very weak. That makes it easy to produce an
> orange negative of enough spectral density to make a snappy
> print on VC fiber paper at a grade 2-2.5
> showing microbanding either. I think this is becuase there is
> a bit more dot gain, which softens the edges of the printer
> dots a bit. Obviously this also means slightly lower max
> sharpness is possible, but the difference is not visible to
> the naked eye, and you have to look carefully even with a
> lupe to pick it up. The lower grittiness is definitely
> boxes, and while the price per sheet is much lower than
> Pictorico, that's still a good chunk of change. Michael has
> agreed to split the packages into 50s that's a lot easier to
> handle, and puts the cash outlay close to what you'spend
> Steve Karafyllakis
Re: New digital inerneg material
2005-01-07 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote:
> particular project.
Thanks for the tip. I'll give it a try. I'm looking for a good Pictorico alternative. Not because of the problems you mentioned, but because Pictorico is getting so flakey lately to deal with. The new owners are really turning a silk purse into a sow's ear.
It's not just that they've discontinued the large rolls of film (which is quite annoying as we make big negs on our 7600) but they just seem to e screwing up stuff lately.
But there are "workarounds" for a lot of your OHP problems, and some might even help on the new film...
Yeah. That stuff is a pain. The best thing the white film does is gives you a bit of diffusion, if you're using a "point source" of light for your contact prints and cuts the light a bit (if you're doing a process where you need to cut the light a bit, like azo, or regular silver paper).
That sounds like you need a slightly more diffused light source. Are you printing silver with an enlarger or alternative processes with a single UV lamp source like a plate burner?
Are you printing in low speed "unidirectional" mode? Exagerated grain is often do to using high speed mode. The printer makes two passes, the dots aren't perfectly aligned on the forward and backward passes, ink dots that are supposed to be next to each other end up on top of each other, and this leaves gaps between them.
Microbanding and graininess are also reduced if you align the printer to the thicker emulsion. It differs substantially from the alignment needed for paper.
A common myth. The opacity rasies dmin and dmax equally. It's just like adding a neutral density filter.
Quite true. You get to see the flaws on both sides of the substrate, as well as the ones inside. Not as much of a problem with a diffusing medium like the white film.
> Also,
> contrast.
Are you using matte black or photo black? When I went to matte black on OHP with a 2200, I found I could get enough density for any paper grade. Surface of the negative is a bit fragile with MK, but if you treat it with the respect due any negative, the end result is a lot better.
Woudl you beleive almost all the pictorico cloudiness is the coating? If you injure the surface, you'll see...
> a grade 2-2.5
Ah, color negatives. I've never figured out where that came from.
> microbanding either. I think this is because there is a bit more dot
Or simply that the alignment on your machine is better for something the thickness of the new material, instead of the Pictorico.
> Obviously
It is. Thanks.
Ciao!
Joe
