BW negative scanning workflow'
2005-01-06 by jsigmonmd24
I have used digital capture with medium format with a good workflow
and printing.
I have missed the conventional darkroom from a processing
standpoint, but not for printing.
Alas, I have been shooting film again(BW only) and I was interested
in any input in terms of the workflow for scanning negative BW film
right up to the point of photoshop. With digital, it's "capture one"
with RAW image processing in photoshop.
With film, (I have a NIkon ls 9000 scanner) for best control of the
negative in a raw sense, does anyone have a reliable workflow?
Vuescan or silverfast ai software? Grayscale or RGB scan modes, etc.?
Many thanks!
Re: BW negative scanning workflow'
2005-01-07 by donbga
etc.?
> Many thanks!
I use the latest version of VueScan with three different scanners,
but not with the N 9000. However I scan in 48 bit RGB TIF and try to
set the white and black point slider at the ends of the preview
histogram.
This usually leaves a flat image which is adjusted later in PS. You
can play with the gamma settings to do some midtone adjustments.
Practice makes perfect. Sharpen in PS not VS, also set the RAW file
output to on. That way if you need to make an adjustment at the
scanner level you don't have to rescan the film.
You can use the RAW file in PS or the regular TIF. I would suggest
using the regular TIF file to begin with.
Don Bryant
2005-01-07 by rgoldman2
I scan my medium format negatives in a Polaroid Sprintscan 120 with
Silverfast. By selecting the negative mode the Negafix component of Silverfast
automatically takes over. I think the following workflow should be appropriate
for most scanning software,though. Choose the bit depth that you want to
scan in (36-48 is preferred unless you have a real memory constraint). Scan
your black and white negatives in RGB not grayscale. Do the grayscale
conversion in photoshop. Some advise scanning at the resolution required for
the ultimate print size  you want, but many , including me, scan at the highest
resolution the scanner will do. In my setup that is 4000 dpi, enough to capture
full information from the 6x7 negative. That results in a pretty large file, but if
you archive it on a CD or external drive, you don't have to scan again when
you change your mind about print size. I do a simple levels adjustment. (black
and white points) Silverfast has an exposure slider as well, and I use that to
kick up exposure on negatives that  look underexposed to me. But go easy on
this step. If the scan is difficult to work with in Photoshop, you can go back and
rescan with another overall density adjustment. The main objective of the
scan is to get all the information, as noise free as possible, from the negative. I
rarely use curves at the scanning stage, preferring to do most of my local
contrast and other adjustments in photoshop. I do not sharpen in the scan
software. After checking that my scan settings are what I want (RGB,  4000
dpi, 36-48 bit), I hit the scan button. When the scan is complete and it opens in
Photoshop, the first thing I do is prepare the file for archiving. Viewing at
actual pixels, I inspect the whole file cleaning up spots and artifacts with the
clone tool or the healing brush. Then I make a copy for a working file and
rename it, saving the original in an archive folder on an external device.
