monitor profiles
monitor profiles
2005-01-10 by jsigmonmd24
Is monitor calibration/profiling necessary for black and white
digital printing and photoshop processing of scanned black and white
negatives?
Obviously a must for color work, just wondering if necessary to
spend the time and expense to calibrate my new Mac display for BW
work only.
Thanks
Re: [Digital BW] monitor profiles
2005-01-10 by Roger Howard
> negatives?
> work only.
A calibrated display is a must for all imaging work. If it's a brand
new Apple display, don't bother tweaking the RGB channels, just set an
appropriate white point and gamma. If you don't have good reason to go
otherwise, try 6500k @ 2.2 gamma. For B&W, gamma will be your most
important setting.
-R
RE: [Digital BW] monitor profiles
2005-01-11 by Paul Roark
>negatives?
>work only.
I used Adobe Gamma for quite a while and then used SpyderPro2 to calibrate
my monitor.  For the B&W I do, I don't think the SpyderPro2 is worth much.
I see almost no difference.
The more important factor is getting the relative densities to look like the
print.  For this, the calibration software does not do a very good job.
I've use a Photoshop preview or "soft proof" (click on View then Proof
Setup) procedure that seems to work better than the other alternatives.  I
have the procedure posted at
http://home1.gte.net/res09aij/Monitor-Profiling.htm .
