QTRgui version 2.1.12
2005-01-13 by Stephen Billard
www.sbillard.org/Shareware/QTRGui.htm
The problem with pipe mode (not-batch mode) on Windows 2000 is fixed. This
mode is needed to support ligatures and accented characters in file names.
Handling of TIFF files has been improved. This version should deal properly
with LZW compression and Alpha channel TIFFs. It will not display TIFFs
saved with ZIP compression, but will show an icon of the image.
Note: QuadToneRIP version d.1d and earlier does not properly print 16 bit
TIFF images or ones with Alpha channels. This version of QTRgui no longer
warns you that your images fall into this category.
Note: Calibration mode has changed with QTRgui version 2.1.12. This change
corresponds to a change in QuadToneRIP version 2.1e. Mixed versions of
QTRgui and QuadToneRIP will prohibit using calibration mode.
-Stephen
 www.sbillard.org/Stephen
