CIS or EZ Refill cart for C86
2005-01-17 by John
2005-01-17 by John
I just order C86 and it have arrived. Should I buy a CIS or Refill cart. with EZ-N inkset? Can someone with experience on both systems give me advice? TIA
2005-01-17 by scott_now_coming
Hi John, First off, I don't have both systems. I do re-fill the new clear carts and you will save a lot of money doing so. I buy pints. If these pints go fast enough, I'm going for the gallons next time. MIS recommends to not use a CIS unless you print everyday. I don't know if you saw that on their website or not. I print a lot, but not everyday, so I'm avoiding it. I guess it will come down to how much priting you do. I'm sure someone here that uses a CIS will tell you the pros and cons. Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John" <firewoodtech@y...> wrote:
> > I just order C86 and it have arrived. Should I buy a CIS or Refill > cart. with EZ-N inkset? > > Can someone with experience on both systems give me advice? > > TIA
2005-01-17 by Paul Roark
>I just order C86 ... > Should I buy a CIS or Refill cart. with EZ-N inkset? I'd go with the easy-refill carts. For me the flexibility to try different combinations of carts for different tones is important. I might also want to switch between glossy and matte blacks. With a CFS, you're locked in. Paul www.PaulRoark.com
2005-01-17 by John
Scott and Paul, thanks for the quick response. The reason I asked is.... those china-made CIS (which most U.S. co. are getting their parts from) are almost the same price as the EZ Refill cart. I can easily order them over the net. I agreed with Paul that EZ Fill is very flexible IF you are going to switch between blacks but I prefer mostly glossy. Scott, even if I am not printing everyday, with EZ Refill, the unused inks are sitting in their own plastic container if you know what I mean.... :-) Thanks again John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > >I just order C86 ... > > Should I buy a CIS or Refill cart. with EZ-N inkset? > > I'd go with the easy-refill carts. > > For me the flexibility to try different combinations of carts for different > tones is important. I might also want to switch between glossy and matte
> blacks. With a CFS, you're locked in. > > Paul > www.PaulRoark.com > > >Hi John, > >First off, I don't have both systems. > >I do re-fill the new clear carts and you will save a lot of money >doing so. I buy pints. If these pints go fast enough, I'm going for >the gallons next time. > >MIS recommends to not use a CIS unless you print everyday. I don't >know if you saw that on their website or not. > >I print a lot, but not everyday, so I'm avoiding it. > >I guess it will come down to how much priting you do. > >I'm sure someone here that uses a CIS will tell you the pros and >cons.
2005-01-17 by Daniel Ridings
> > I'm sure someone here that uses a CIS will tell you the pros and cons. > I use the CIS. Pros ... you can print to your hearts desire without blinking ... as long as you have paper. I love that part. Pro: You've got a lot of ink and don't have to worry about refilling, resetting chips or what-not. Cons ... the clips with adhesive that you use to hold the tubing in place is not adhesive enough. Mine come loose once or twice a day. If you make a habit of pressing that back into place every now and then (I'm up to a couple of times a day) all is well. But you can't use the "autoprint" program to print a page a day if you're gone for a few days. If the clips come loose (and mine do all the time) then they will block the printing mechanism and the printer goes into error recovery mode. Another con: Make sure you choose the ink (warm or neutral) that you want from the start. You won't be able to play around with degrees of warm by having neutral inks in most positions and a warm ink in strategic ones. Another con: You're stuck with your black (Eboni or Photo Black). So even if the system is made to work with matte and glossy, you'll be limited to the one you primed your CIS with. Not a great problem for me, I like matte and Eboni works reasonably well with Ilford Gallerie Smooth Pearl (but not smooth Gloss). I'm considering cutting up a slit in the side of the C86 at just about the position of the left-hand clip and then running the tubes on the outside of the printer rather than along the inside of it. That would solve the problem with clips that loosen all the time. Daniel Ridings
2005-01-17 by Jake Hellbach
Hi, I have a question about the new carts from MIS. I bought the new clear carts a month ago and this weekend had to re-fill them. They worked fine but after a few photos I noticed some missing jets on two of the carts. When I pulled them out they had bubbles around the bottom of the cart stopping the flow of ink. I had to use the bottom fill adaptor to extract some ink to get rid of the air. Is this normal, do you have to suck some ink after re-fill? Thanks, Jake Fine Art Photography www.jakehellbachphoto.com [Non-text portions of this message have been removed]
"Scott, even if I am not printing everyday, with EZ Refill, the unused inks are sitting in their own plastic container if you know what I mean.... :-)" John, That's not a problem, if the carts sit for a reasonable amount of time. However, for whatever reason, the CIS is prone to sucking in air into the system is it's not used daily, and the ink drys out around the head. Link to InkSupplies'website that talks about this situation (scroll down the page): http://www.inksupply.com/index.cfm?source=html/utez.html I'll post this from their website: "If you are a frequent printer or doing some production work, then we recommend you purchase a MIS Continuous Flow System for your C82, C84 or C86 printer. This will save you a tremendous amount of money. The cost to operate a CFS is at least 10 times less than using cartridges. If you only print occasionally, then do not get a CFS. If left idle for 3 or 4 days at a time, CFS units can start to develop problems. Our AUTOPRINT program (see CFS Page- halfway down) can be used to prevent problems from occuring, provided the printer and its computer remain powered. " Their is a program that you can install on your computer to automatically run a purge print each day, to try to prevent problems from non-use. But I think that would be im-practicle unless you printer, say, 5 days a week. Or, maybe you left town for a day or two or whatever. I just hate to see someone have a bad experiance from the start and get turned off to the whole b&w digital printing process. And, I'll close with this: Not including the price of the carts, the re-filled carts cost $1.37/each to re-fill if you buy pints. Buying gallons, the cost drops to $0.98 each to fill. With that kind of savings, I'm not going to mess with the CFS. Let us know how it works out for you. Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John" <firewoodtech@y...> wrote: > > Scott and Paul, thanks for the quick response. > > The reason I asked is.... those china-made CIS (which most U.S. co. > are getting their parts from) are almost the same price as the EZ > Refill cart. I can easily order them over the net. > > I agreed with Paul that EZ Fill is very flexible IF you are going to > switch between blacks but I prefer mostly glossy. > > Scott, even if I am not printing everyday, with EZ Refill, the unused > inks are sitting in their own plastic container if you know what I > mean.... :-) > > Thanks again > John > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" > <paul.roark@v...> wrote: > > >I just order C86 ... > > > Should I buy a CIS or Refill cart. with EZ-N inkset? > > > > I'd go with the easy-refill carts. > > > > For me the flexibility to try different combinations of carts for > different > > tones is important. I might also want to switch between glossy and
> matte > > blacks. With a CFS, you're locked in. > > > > Paul > > www.PaulRoark.com > > > > > >Hi John, > > > >First off, I don't have both systems. > > > >I do re-fill the new clear carts and you will save a lot of money > >doing so. I buy pints. If these pints go fast enough, I'm going for > >the gallons next time. > > > >MIS recommends to not use a CIS unless you print everyday. I don't > >know if you saw that on their website or not. > > > >I print a lot, but not everyday, so I'm avoiding it. > > > >I guess it will come down to how much priting you do. > > > >I'm sure someone here that uses a CIS will tell you the pros and > >cons.
I would say that is nornal. I re-filled 3 Saturday night. I noticed my PK cart had bubbles near the bottom of the sponge side. I removed about 2 or 3 ml of ink with the adapter. The bubbles were still there, but the carts printed fine. I'm like Paul, if I use the syring and a bottom adapter and remove a ml or 2, I get a good nozzle check on the first try. Scott --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jake Hellbach" <jake@j...> wrote: > Hi, > I have a question about the new carts from MIS. > I bought the new clear carts a month ago and this weekend had to re- fill them. > They worked fine but after a few photos I noticed some missing jets on two of the carts. When I pulled > them out they had bubbles around the bottom of the cart stopping the flow of ink. I had to use the bottom
> fill adaptor to extract some ink to get rid of the air. > Is this normal, do you have to suck some ink after re-fill? > > Thanks, > Jake > > Fine Art Photography > www.jakehellbachphoto.com > > > > > [Non-text portions of this message have been removed]
Jake, I routinely "prime" the carts by sucking some ink out the bottom with a bottom fill adapter. (I shortened a standard one's snout to 7 mm to get a better seal.) That seems to pull this air bubble out. Air doesn't seem to be a problem when re-filling. Paul www.PaulRoark.com
-----Original Message----- From: Jake Hellbach [mailto:jake@...] Sent: Monday, January 17, 2005 5:49 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Clear cart question Hi, I have a question about the new carts from MIS. I bought the new clear carts a month ago and this weekend had to re-fill them. They worked fine but after a few photos I noticed some missing jets on two of the carts. When I pulled them out they had bubbles around the bottom of the cart stopping the flow of ink. I had to use the bottom fill adaptor to extract some ink to get rid of the air. Is this normal, do you have to suck some ink after re-fill? Thanks, Jake Fine Art Photography www.jakehellbachphoto.com [Non-text portions of this message have been removed] Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
2005-01-17 by Peter De Smidt
Hi Folks, I just found this forum. It looks like a great place. I'm a traditional wet darkroom user, and I don't plan on giving that up anytime soon. In fact I'm just in the process of setting up an 8x10 De-Vere horizontal enlarger. In any case, over the years I've acquired a fair number of negatives with flaws, such as wayward hair or other distracting elements; and also a number of them that would be very hard to dodge and burn properly using traditional methods. I hope to eventually be able to print these digitally. While I might eventually try Dan Burkholder's image setter negative technique, I'd prefer to be able to do as much of the work in house as possible. As such, I'm considering getting an inexpensive inkjet printer, perhaps the Epson c86, which I'd use with Mis EZ inks. I'd like these prints to looks as much like my prints from medium and large format negatives onto Ilford's glossy silver gelatin VC fiber based paper, which I air dry. This gives a soft sheen. So I have a couple of questions. Would the Epson C86 and Mis EZ inks allow me to make prints that are at least close to my more traditional methods? What paper would best match the qualities of Ilford's glossy silver gelatin fiber paper? I don't like glossy resin coated silver gelatin prints, as they are too shiny and plasticy looking, and I don't like matte paper for my work. Would someone who used the c86 with Mis EZ inks be willing to send me a small sample print? Regards, Peter De Smidt PS I do have some Photoshop CS experience, although I'm not an expert by any means. At the moment I'm working through Karin Eismann's book on digital retouching.
2005-01-18 by Paul Roark
Peter, >... I'm a traditional wet darkroom user, ... Many of us still have our darkrooms. >... considering getting an inexpensive inkjet printer, >perhaps the Epson c86, ... with Mis EZ inks. Yep, that's what I recommend as a starting place. > I'd like these prints to looks as much like my >prints from medium and large format negatives onto Ilford's glossy >silver gelatin VC fiber based paper, which I air dry. This gives a soft >sheen. Under glass this is relatively easy, since the gloss of the glass is what people see. If there is no glass, the surfaces of the papers differ. I like the sprayed Epson Premium Semimatte (only in rolls) or Semigloss (in sheets). This line of papers (and perhaps the Costco glossy paper) are about the only glossy papers that may be archival. Most glossy papers have acidic paper interiors. The Epson Premium line and Costco have buffered interiors. Wilhelm gives the Epson Premium papers an estimated dark storage life of >200 years, which is the best he gives any paper, I believe. >... Would the Epson C86 and Mis EZ inks allow me to make prints >that are at least close to my more traditional methods? Yes. > What paper would best match the qualities of >Ilford's glossy silver gelatin fiber paper? >I don't like glossy resin coated silver gelatin prints, >as they are too shiny and plasticy looking, That is why I like the Semimatte and Semigloss. These papers need a post-printing spray to get rid of bronzing. This spray also protects the prints, however. > I don't like matte paper for my work. I think the matte paper look is a problem many have had with inkjet printing. However, if they are going to be under glass, they can look very good. There is probably noting that is more archival and easier to frame either. Tape hanging a matte print is much easier than dry mounting. For more information on the C86 and other options, see my ink information page at http://home1.gte.net/res09aij/index.htm . Good luck. Paul www.PaulRoark.com
2005-01-18 by Kip Babington
I had the same trouble with the clips coming off. Solved it with Scotch brand Exterior Mounting Tape, product 4011. This is an extra strong double stick foam tape. It took a bit of effort to get all the old tape off the clips, but I then cut appropriately sized squares of the exterior tape and haven't had a clip come loose since. Cheers, Kip Daniel Ridings wrote, in part:
> <snip> > >Cons ... the clips with adhesive that you use to hold the tubing in place >is not adhesive enough. Mine come loose once or twice a day. If you make a >habit of pressing that back into place every now and then (I'm up to a >couple of times a day) all is well. But you can't use the "autoprint" >program to print a page a day if you're gone for a few days. If the clips >come loose (and mine do all the time) then they will block the printing >mechanism and the printer goes into error recovery mode. > >
2005-01-18 by Peter De Smidt
Paul, Thanks for your help. You're willingness to spend the time sharing your expertise is truly laudable. I'll give the C86 Mis EX inks a try on the semi-matte and semi-gloss papers. I do have a couple of further questions. First, you mention spraying the prints with a coating. It's my understanding that these types of treatments have been problematic, in that they themselves have caused print deterioration, despite what the manufacturer's have claimed. The anecdotal info that I saw concerned silver gelatin prints, and so this may not be a problem here. In his book _Post Exposure_, Ctein says that one brand caused problems while another did not, at least not yet. Unfortunately, he didn't specify the brands. While it's way too early to tell, as inkjet prints haven't been around that long, is the consensus that these print sprays aren't harmful? Have accelerated aging tests been done with these sprays? Second, can inkjet prints be dry mounted? I prefer to mount all of my display photographs with Seal's Colormount dry-mount tissue on museum board. The prints and backing boards are put in a press heated to 200F for 3 minutes. Would this be a problem for the Mis EZ inks? Regards, Peter De Smidt
Peter, >... you mention spraying the prints with a coating. It's my >understanding that these types of treatments have been problematic, in >that they themselves have caused print deterioration, despite what the >manufacturer's have claimed. Wilhelm has tested the PremierArt spray and found that it increased the lightfastness of the prints it was applied to. My fade tests show the same thing. >... can inkjet prints be dry mounted? Yes. I use a Seal archival tissue at 170 F. One minute in the press does the job. I would hold the heat down as much as possible. Paul www.PaulRoark.com
