Removing pizza wheels from the 21/2200
2005-01-22 by Steve Kale
Maybe I am just late to this but I don't think anyone had managed to remove the pizza
wheels from the 21/2200.  I just printed a great print with glop and FSN inks only to find
that it had pizza wheel marks all over it.  In short, I was prepared to wreck a printer trying
to get rid of those damn wheels.
I have removed the pizza wheels and the printer still works.  I will test it over the next few
days to see if there are any problems.
Removing the wheels was surprisingly easy.  I simply lifted the print head up with the lever
to gain a little space.  I then got a fine screwdriver - the sort one uses to fix glasses, for
example - and simply prized the wheels out from the top.  They clip down into place and
simply spin on little springs (they are not spring loaded or anything, the "axle" they spin
on is simply wound wire like a spring) and so popping them up is very easy.  I doubt there
is any chance of getting them back though as the screwdriver damaged many of the little
spring axles in the process.  Put your finger of your free hand over the wheel as you prize
them out else they will simply fly anywhere - including into the interior of the printer.
The wheels are not mechanically powered in any way.  They simply roll over the top of the
paper.  As a result I am somewhat confidant their removal won't bother the printer in any
way.
Don't bother unclipping the black thing they all clip into (as described in some other
instructions for other printers).  Just lever each wheel out from the top, along with its axle.
Not that I think it matters, but I did all this with clips in place to lift up the rollers a la MIS'
instructions.  They all stayed in place throughout the process.
Cheers
Steve
Re: Removing pizza wheels from the 21/2200
2005-01-22 by alankushnir
I have printed hundreds of prints on my 2200. I am quite critical of
imperfections. I have not noticed any issues that are related to the
pizza wheels. Is it possible that the printer is not functioning
properly and that is what is causing  your problem?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale"
remove the pizza
down into place and
many of the little
> way.
> Cheers
> Steve
2005-01-22 by jimpegoda
of
Take a glossy 2200 print out into the sun or put it under a bright
light and tilt the print and you might see the dreaded pizza wheel
tracks. They are generally invisible but once you see them they get
under your skin and give you "crazy eyes".
-Jim
2005-01-22 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jimpegoda"
> of
> the
> -Jim
Holy anchovies, Batman, where's my pizza (wheel marks)? Unless Epson
Premium Glossy Paper just isn't glossy enough, I'd have to assume I'm
blessed with one of the "special" non-marking 2200 printers--not a
trace of pizza wheel marks. And I know what they look like from the
old days-- printing with my SP 750 (with it you didn't need to go out
in the sun and tilt the print to a magic angle--they were quite
obvious in room light). I'm can't deny that some 2200 printers don't
have this problem, but perhaps there other options (i.e., a
readjustment of some kind) lass drastic than the wheelectomy
procedure.
One consideration in this regard is the use of High Speed mode. I
never have used it, and I wonder if those getting pizza wheel marks
are generally using High Speed(?) This conceivably might be an issue
since those wheels contact the paper after the ink application, so if
there's less time to dry, the paper surface may be too soft at that
point (no pun intended). Or can you see the marks in the non-printed
areas, too?
Phil
2005-01-22 by bghess_sp
I got rid of the problem without removing anything from my 2200.  All
I did was insert a small folded piece of paper under the metal housing
 that holds the pizza wheels.  The entire housing is hinged and can be
lifted about one-half an inch, creating a gap between the wheels and
their counterparts.  There is a white plastic wheel assembly on the
left side of the metal housing, this is where I inserted the piece of
paper (between the plastic wheel and the metal roller beneath).  This
wheel assemby is powered and rolls at the beginning of a print, so it
may take some trial and error to get the paper to stay, although mine
stays in place after some minor shifting.  Anyway, the idea is to get
the entire metal housing lifted just enough to pull the pizza wheels
away from the print surface, but not enough to block the print head
from sliding across the print (there is a very small margin of error
here I think, so be careful its not too high when attempting, I don't
know what would happen if the print head assembly struck the housing).
I'm sure there are other ways you can lift the metal housing, this is
just the way it worked for me.  Also this way, you can remove the
paper and but the printer back in original condition if needed.
remove the pizza
down into place and
many of the little
> way.
> Cheers
> Steve
Re: [Digital BW] Re: Removing pizza wheels from the 21/2200
2005-01-23 by Steve Kale
I think a potential issue with that is that you are moving that whole
assembly closer to the print head.  I think if you had something like a very
fine pair of pliers (or were simply more careful prising the rollers up) you
could remove the pizza wheels without damaging the fine spring axle.  As I
got the hang of it I did not damage the last few.  In that case I think you
could potentially put them back.  They really did seem to simply be clipped
in with the fine axle there to simply keep them upright a little better and
hence avoid them jamming.
I have printed several prints since removing them on both A4 and A3 paper.
No issues thus far and no more pizza wheel marks.
> From: bghess_sp <bghess_sp@...>
> Date: Sat, 22 Jan 2005 21:18:14 -0000
> Subject: [Digital BW] Re: Removing pizza wheels from the 21/2200
