Epson 3000 opinions?
2005-01-22 by mojojones2001
Hello All,
This is my first post to this group. (I've got a lot of questions but
I'll try to start off slow!)
I've been printing for several years with a couple Epson 1200's; one
set up with Generations Archival color inks and one set up with
PiezoTone with generally good results.  However I'm looking to branch
out and do some experimenting with other inks, workflows, custom
mixing, etc.  After looking at some of the option's it seems that
there aren't as many options for the 1200's as other printers so I'm
looking for another way to go.  I looked at maybe going with a 1280 or
2200 (though it seems a waste to use a 2200 for messing around).  Then
I saw that 3000's were going fairly cheap on ebay.  There seems to be
considerable workflow/RIP support for them and they have individual
carts for switching inks, but they are quite long in the tooth at this
point.  I remember that some time back there was a lot of talk about
poor paper handling and clogging so I was wonder what you all thought
about them now and recommendations on whether it would be worth the
setup in light of more modern printers.
Thanks for your help,
John
Re: Epson 3000 opinions?
2005-01-22 by dlruckus
Hi John.
The 3000 is exactly what I did and I don't in the least regret it.
It's a fine machine despite being nearly as long in the tooth as I am.
I thought, because of talk, that it wasn't up to par quality wise due
to larger dots but I found it not to be a problem for larger prints.
Particularly so with Quad printing but even with color pigs where I
expected it to be a dog. I think it fine for 11x14 and up going on the
wall.
You will find it is great for experimenting with mixes because you can
very easily empty/flush/fill cartridges for it and Mis has new
inexpensive emptys available as well as cheap dye carts you can also
flush and use.
Mine has never clogged, period, which I certainly can't say about my
1200s. That said, you need to pay some attention to what you are going
to be mixing in the machine and cartridges.ie: NEVER mix UTs, UCs, any
Eboni or like later inks with any residues of inks with ANY dye content.
I haven't tried forcing 300gm heavy papers through it but have no
problems with the 200-240 range. There are others who found ways to do
so and some who never could get 300 to work no matter what they did.
In my estimation it is a good way to go for what you want to do. Also
a bonus of larger print capability--and--in the $300 or so range as
opposed to $2000 or so w/inks etc for an EP4000.
Hope this is helpfull.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mojojones2001"
<mojojones@c...> wrote:
> Hello All,
> John
2005-02-19 by mojojones2001
Sorry for the late reply, but thanks to those who responded with their
experiences.  I was able to buy a 3000 on ebay and look forward to
experimenting.
Thanks again!
John
> Hello All,
> John
