RGB vs. CMYK for curves
2005-01-25 by evanj1969
when building curves in Photoshop for UT2/UT7 etc.. everyone seems to
be working RGB vs. CMYK.
does RGB have an advantage over CMYK (excluding file size)?
would it not make more sense to control each color jet with its
corresponding channel in Photoshop???
i've always work in RGB, but is it better/easier?
anyone have thoughts or experience using each for the same thing?
Re: [Digital BW] RGB vs. CMYK for curves
2005-01-25 by Martin Sluka
R=G=B -> neutral grey
C=M=Y=K -> ???
Martin
but if i'm actually printing with gray inks, or cool/warm grays, not
color inks,  what good does having equal values of R.G.B do me? it
doesn't mean my print will be neutral, only my photo in photoshop.
 does that make sense? after aplying an RGB curve to get the (gray)
inks to "print" properly, the image is such a rainbow, the R=G=B ->
neutral grey doesn't apply.
 or is there something i'm missing in you previous post?
 maybe i'm unsure of what you mean.
> C=M=Y=K -> ???
> Martin
2005-01-25 by ldina
Evan,
RGB mode provides more options for photo manipulation in PS, more
filters, smaller file size, etc.  Also, conversion to CMYK generally
reduces the gamut depending on which flavor of CMYK you choose.
Probably not as big a deal for monochrome images, but picking the
wrong CMYK in a color managed workflow could needlessly reduce
dynamic range (you generally wouldn't want to convert to US Web
Uncoated unless you want a lackluster inkjet print).  Most inkjet
printers, even though they print with CMYK inks, expect RGB data
unless you are using a CMYK RIP.  So, if you send CMYK data, the
driver converts back to RGB so it can decide how to convert back to
CMYK again.  Each of these conversions comes at a price.  I'm not
sure how programs like QTR and IJC/OPM process CMYK data.
I like RGB partly because it is gray balanced, R=G=B.  If you have
the tools and software to create your own profiles, ideally you would
want R=G=B to display accurately and print dead neutral on paper, and
this can be measured with a spectrophotometer.  If you achieve this,
then you have more control and predicitability in your work.
That being said, if you find you get better results with CMYK and
find it more intuitive, use it.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "evanj1969"
not
> > C=M=Y=K -> ???
> > Martin
The question was about advantage of RGB<->CMYK, not about printing
greyscale and control it with RGB curves.
CMYK has one additional channel - black one. It is generated after
conversion of RGB to CMY from pixels, where are all CMY values > 0 .
The generation of black chanel is most sensitive part of CMYK
workflow and "standard" CMYK profiles have black channel generated
for ofset, not for inkjet. So if you use CMYK data in some kind of
ofset space, the inkjet RIP or driver must konvert this CMYK to
CMYK(mck) space for particular inkjet. And:
Martin
2005-01-25 by sinwen
When you play on let say the Red channel, you play only on it, whilst if you play on M you change C and Y as well and it is virtually impossible to control. K is there because C+Y+M is not printed as deep black by our technical devices, so we help it in adding K. Read a little bit on color theory, you'll get it all.
Printing Color or Quadetones makes no difference, when you change one you change the other two.
  Sent: Tuesday, January 25, 2005 10:36 AM
  Subject: Re: [Digital BW] RGB vs. CMYK for curves
  > C=M=Y=K -> ???
  > Martin
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  Yahoo! Groups Links
2005-01-26 by evanj1969
> Martin
actually, that is precisely what the question was. i posted it.
here it is again.
be working in RGB vs. CMYK.
 i was referring to the application of RGB/CMYK curves only for
printing purposes, not asking if working in CMYK is better/worse.
 UT2/UT7 are for B&W printing. they are not "color" inks so to say. i
was inquiring as to WHY some (or most all) choose to apply RGB curves
after all editing is done & before printing (as opposed to CMYK).
 this post cleared it up and answered my question.
 groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/54843
  thanks all the same for your input.
  i appreciate all who have contributed.
2005-01-26 by Ernst Dinkla
The Epson driver knows only RGB as the input format. When you
deliver CMYK (in any fashion) to the driver it will first
convert it to RGB and after that apply its own CMYK conversion
again. So there's no advantage to use the CMYK descriptions
for B&W quad sets if you are using the Epson driver. There's
even less transparency in what happens to the data through all
the conversions when using CMYK curves in PS. That's also true
for color printing with the Epson driver.
It would be nice to control each color jet (C-M-Y-K or
C-c-M-m-Y-K(-k)) but even some commercial RIPs do not allow
that: the "RGB" ones are like the Epson driver but there are
also RIPs around that only use CMYK channels so the 6-7
printers do not get a true 6-7 channel control. The special
B&W RIPs now around are actually controlling the individual
channels but you can't consider that to be CMYK curves either,
they are grey + toner curves in a sense. K generation isn't a
result of CMY amount in those curves.
I'm using a Wasatch SoftRip and have to use a kind of CMYK
curves to get an Epson 9000 with UT in control. But I apply
them in the RIP calibration software, the RIP gets a kind of
greyscale images as input and the conversion is done with
weird CMYK curves, K generation is taken out by other means
Ernst
