> I've been successfuly using QTR to print on manually fed papers using
> the Mac, so let's try and see what you are doing differently from me.
> 1. I feed the paper first and wait until the machine accepts it and is
> ready to print. I have only done this through the front slot with QTR.
> 2. I print using QTR from PS
> I know the 4000 is a little finicky about what setting it needs for it
> to actually print on manually fed paper, but it usually gives you a
> "Forbidden Media.." warning when the setting does not match the
> inserted sheet. Wait a sec, you say it gives you a "Paper Out"
> message? That generally means the tray is out of paper. So the printer
> is expecting a sheet of paper in the tray, but instead you have fed it
> manually and it doesn't know this. For top fed manual sheets, the 4000
> wants to see any paper with the word Photo in it. So in other software
> (let's say ImagePrint), printing onto paper manually fed thru the top,
> one would have to choose "Photo XXXX Paper" for the 4000 to accept the
> sheet and print on it.
> So you might want to try choosing a paper in QTR's Printer Features
> popup that includes the word Photo, even if it is counter-intuitive,
> to just fool the printer into printing.
> Nick
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bromois"
> <bromois@y...> wrote:
> > the paper is Hahnemuhle photo rag 188(11x17), and is top fed. I
> have
> > turned the 4000 off/on, reset the utility, etc..
> > Maybe i will try to re-install, or try another paper....tomorrow.
> > Any other input is GrEATLY appreciated.
> > thanks.
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lambonick"
> > <BMWNick@i...> wrote:
> > > Where are you manually feeding the paper? Thru the front slot
> (flat
> > > feed), or thru the top
> > > slot? And is the paper a custom size? And presumably you've tried
> > > turning the 4000 off/on
> > > just to reset it.
> > > > Hello, i have installed QTR on a Mac running OSX 10.3.6. and am
> > > > attempting to print to a 4000. the problem is that when i set
> to
> > > > print, as the utility is spooling the file, the 4000 spits out
> the
> > > > manually fed sheet after alignment and says "paper out". if i
> > > > re-feed, same thing happens. Being that there is no help file
> > with
> > > > the 4000 QTR install, i am kind of at an impass for instructions
> > on
> > > > what the problem might be.
> > > > I tried adjusting paper size, margins, and source profile to no
> > > avail.
> > > > Does anybody with experience in a 4000/QTR/OSX setup have any
> > > input??
> > > > I have experience running 2200/QTR/Windows, so maybe it is
> > something
> > > > specific to Mac QTR that i am missing??
