QTR,dMax and other stuff
2005-01-30 by Fred Drury
For openers, let me echo the observations of others and salute this group
for its contributions to the art, and its focus on helping everyone on the
list improve their results.  It truly is a great forum and an incredible
source of not only information but also inspiration.  Thanks to all of you
... I find value every day's messages!
In a recent message to the list Steve Kale described his technique for
countering what he describes as flatness in QTR prints.  In part he
suggested:
If you want to see on screen the effect this weak dMax and QTR's
> linearization do the following.  Open a Gray Gamma 2.2 step wedge.  Add a
> Curves Layer (Layer->New Adjustment Layer->Curves->Enter).  Grab
> the bottom
> left anchor point and slide it up to (0,41) and grab the top right anchor
> and pull it down to (255,243).  Now look at how the input/outputs for the
> points in the middle have changed eg 128. For the most part, the image is
> lighter because the better part of the straight line has been shifted up
> (128 has gone to 142).  (Note that there is still nice visual separation
> between the steps on the screen which is QTR's linearization goal.)  When
> people say an image is flat it is largely, I believe, because all the
> mid-tones have been brightened.
He also suggested a method for countering the 'flatness' problem:
Add another curves layer. Lock (128,128).  Grab (63,63) and pull it down a
> little say to (63,43).  Grab (192,192) and shift it up a little say to
> (192,213).  This is what is meant by an s-curve - it is shaped like an s.
> You are adding a little punch to the highlights and darkening the
> shadows a
> little without shifting the mid.  You can view the effect of the second
> curve by itself by turning the visibility of the first off.  The effect on
> the image though will be the two curves combined.  The selection of points
> and how much to move them is really an artistic one but you have to judge
> the two together which is why I said keep the first curve visible.  Note
> that the first curve (a representation or simulation of what the RIP is
> doing) shifted the mid up point up and the second left it the same - ie
> still up.  So your mid grey will still be lighter than the original image
> without the curves.  You might choose to pull the mid darker in the second
> curve to counteract the effect of the RIP.  It's up to you.
I have done some experimenting with this method and thought I would both
share the results with the group and seek suggestions for further
experimentation. I first printed the image using QTR on EEM along with a 21
step wedge file.  I'm printing on a 1280, using the MIS UT2 CIS and Roy's
'neutral-2' profile, 1440 super, Better.  Measuring the step wedge with my
i1-Photo instrument gave the following results 'L' results: 100%(black) -17,
90%-26, 80%-35, 70%-42, 60%-51, 50%-57, 0% (paper)-97.  I then used a
applied an 'S' curve of the type Steve described, reprinted on the same
sheet of EEM along with another 21 step wedge file.  The contrast was
clearly increased and the image had substantially increased 'punch'.
Comparable results were: 100%(black) -17, 90%-22, 80%-28, 70%-36, 60%-47,
50%-57, 0% (paper)-97.  The lowering of the 'L' values in the 60-90% range
(and increased values in the 10-40% range) did produce a more attractive
result.
A couple of questions for the group:
1)  The L=17 value corresponds to an RGB result of something like 46,46,46
... ... is this the best (darkest) black I can expect to obtain using EEM?
(Note: The 100%(black) result on Premium Luster (neutral-3 profile) was L=6)
2)  What alternate papers could I choose that would improve my blacks?, and
how much improvement should I expect?
3)  Is there a way to convert my measurements to an equivalent dMax...
alternatively, how can I measure dMax?
4)  Would working in Roy's recently posted Lab grayscale workspace permit
moves towards improvement?
Some further questions for the group (I'm working with a PC system and so am
anxiously awaiting the information on how those of us in PC land can go
about making profiles):
1)  Does anyone on the forum have any idea when this information is likely
to be available?
2)  I gather we PC'ers cannot currently do any soft proofing either?
With many thanks to this forum for past and future assistance,
Fred Drury
Markland Imaging
Re: QTR,dMax and other stuff
2005-01-30 by ldina
Fred,
46,46,46 ... is this the best (darkest) black I can expect to obtain
using EEM?
A measured L* value of 16 - 17 is generally about the best you can
expect from EEM.  Different inks may give a little more or less Dmax,
but that is generally the range.  Some people have tried various
coatings to improve dmax, laminations, etc.
was L=6)
Yep, glossy, satin and other coated papers will give you great Dmax,
like you said, typically in the L* range of 4 to 10, again depending
on paper, ink, etc.  Many people are beginning to use these papers
and spray them to reduce bronzing, etc.  Mounting behind glass also
helps.
blacks?, and how much improvement should I expect?
Kirkland Glossy (Costco) gives great dmax for a glossy paper, but is
available only in 8.5X11 max to my knowledge.  Epson Prem Glossy, Ep
Prem SemiMatte, and other will give pretty good dmax.
dMax... alternatively, how can I measure dMax?
Bruce Lindbloom's site has a companding calculator which converts
between L* and density.  www.brucelindbloom.com.
permit moves towards improvement?
You get a better view of what you will see in print, but no, it is a
paper/ink limitation.
Lou
Re: [Digital BW] QTR,dMax and other stuff
2005-01-30 by Steve Kale
Fred
Take a look at Roy's latest stuff.  He has found a way to use the Perceptual
Intent and icc profiles to manage the required compression of tonal range.
Quite cool. The way to think about it is an automatic way of dealing with
the issue I was describing and one that draws on all the skill/technology
already available to the colour-managed world.  At the end of the day, while
your image file can have a range in L from 0-100 you will always be
constrained by the print/ink media.  Roughly, a range of 96/97 to 16/17 for
matte paper and down to 5-9 for RC paper.  Until we get better inks this is
what we have to deal with.  The use of glop has greatly improved the use of
RC paper and opened up potential dMax from around 1.65 to 2.2-4.  Less tonal
compression required as a result.  Working with Roy's Lab space doesn't
expand the available range but does mean that it is easier to deal with the
tonal compression in a more rigorous fashion. Take a look at the note on his
website.  It also means soft-proofing is much easier.  In essence, he uses
Perceptual Intent to do the job of the s-curves.
Steve
> From: Fred Drury <fotofred2@...>
> Date: Sun, 30 Jan 2005 11:57:16 -0600
> Subject: [Digital BW] QTR,dMax and other stuff
> suggested:
>> the bottom
>> shadows a
> result.
> to be available?
> Fred Drury
> Markland Imaging
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND
> �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
