QTR settings for Costco glossy
2005-01-31 by zdirk99
I know that this has been addressed many time here but I am unable to find this info in the forum archives. The one posting from some months ago that I saved said to use "UC- EPhotoPaper". I do not find this in the Curves choices. Could any of you successfully using this paper, please offer your suggested QTR settings. Thanks. David Keenan Austin, Texas
2005-01-31 by Pieris Berreitter
David, The nice selection of curves is only available to 2200 users. People with lesser printers have to work with a smaller selection. I just spent the evening fixing my Kirkland workflow. Here's what I'm doing on my 1280 with UT2, Eboni black (you didn't specify what you have, I hope it's the same!) QTR Photo Quality Glossy Paper 1440 Resolution / Better Quality 60% UT2-EPremLuster-neutral-3 40% UT2-EPremLuster-carbon-3 Ink limit, gamma = 0 This gives a coldish print. Swap to 40%/60% for a warmish print (the differences are subtle). So far I have noticed very little difference between paper types (Luster, Photo Quality, Premium Glossy) but you may want to try them. You can try printing straight to QTR like this, but I had problems with tonal separation in the 30-40 range. You can try Roy's profile, which works for some of my pictures but not others. For images that need more low-end tonal separation I made a curve with a very sharp toe that solved the problem. Here's my Kirkland curve: 0->0 29->23 35->35 40->40 64->64 128->128 I have not fine-tuned this but it should be a good start. -Pieris digital darkroom blog: www.pmb.net/darkroom --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "zdirk99" <ausdlk@s...> wrote:
> > I know that this has been addressed many time here but I am unable > to find this info in the forum archives. > > The one posting from some months ago that I saved said to use "UC- > EPhotoPaper". I do not find this in the Curves choices. > > Could any of you successfully using this paper, please offer your > suggested QTR settings. > > Thanks. > > David Keenan > Austin, Texas
2005-02-01 by David Keenan
Pieris -- I'm using the standard UC ink cartridges in my 2200 at the moment. I did some printing last night with the following settings: Premium Glossy Photo Paper 1440 super Ordered 100% UCpk-EPremSemiGloss-cool Ink Limit & Gamma = 0 and got what I thought was a decent print. Compared to the same image printed on EEM, the glossy surface definitely provides more "snap" and "blackness". As expected when setting Ink Limit to +10 on a test print, there was a loss of shadow detail. -- David Keenan, ausdlk@swbell.net on 2/1/2005
