RE: [Digital BW] C86 - question about MIS neutral tone ink
2005-02-01 by Lee Hiers
On 1 Feb 2005 at 16:37, Yang, Howard wrote: > I'm also interested in C86 w/MIS EZN. Can someone > provide a shopping list of all the parts needed from MIS > to do my own refill? I just bought the pre-filled EZ ink cartridges and use a syringe/needle that I got from my local druggist for refilling. I believe it's a 30cc syringe, but the carts hold much less than this. I inject the ink through the rubber stopper on the factory carts. One bottle of Eboni ink, and a bottle of either EZN or EZW (any position - the CMY inks are the same). A set of cartridges - either pre-filled, or the new clear empties. You'll need one for each position...the chips are different, even though the inks may be the same. I've not yet tried the clear easy-refill carts, but will probably order a set of these with my next order. I think Paul says to use a bottom-fill adapter if you use these carts, but I'm not sure. You'll also need a chip resetter. That should just about do it... HTH, Lee -- Lee Hiers, AA4GA Cornelia, Georgia "Have Dobro Will Travel"
