OT: Using QTR to overcoat colour prints with glop - A3+ R800 now...almost
2005-02-01 by Steve Kale
Given the discussion when glop first became "flexible" with the refillable carts I thought I
would post a couple of observations.  If anyone wants to follow up with me I guess they
can contact me off-list.  I set up a QTR "curve" to apply glop as an overcoat (15% flat) to
my colour images printed with the Epson driver.  (For B&W images glop can be introduced
immediately at printing as one of the inks.)
All I can say is that the glop does an amazing job - even if MIS weren't happy with it and
intend to bring out a revised version!  It is like the glop version has had the dust brushed
of it.
One issue though.  Page sizes.  I was hoping to be able to simply reprint an image with
QTR and the curve instead of the Epson driver - the curve would simply lay down glop in
all non-pure white areas of the image.  (You can send Adobe RGB files to QTR - OS X
simply converts them on the fly to greyscale files.)  However, QTR's page size (centred)
does not match the Epson "No Margins" page size and so the same image is a fraction
smaller with QTR than Epson - that's how I could easily see the glop vs no glop
comparison.  It's a real shame because the alternative is to print the entire page with glop
which obviously uses a lot more glop.  Also QTR will not print the bottom 1.5 cm or so of
the page (A4 centred means it doesn't print the first 1.5cm.)  At 15% application, the glop
does not have any real visible colour but the sheen of the paper changes and it is
noticeable even on paper white.
I did the tests thus far with A4 paper.
